: ATS-V Manual Transmission
JFJr
03-28-13, 04:13 PM
Is it unreasonable to expect the Tremec 6070 as an option? I doubt it would be limited to the C7. Of course physical size might come into play as it did in the V1; the reason a manual was the only transmission offered.
Jud
rand49er
03-28-13, 05:54 PM
That transmission would make a ton of guys happy ... a ton.
M5eater
03-30-13, 03:47 PM
I would think it would be far more likely you'll see an upgraded form of the tremec in the 2.0T. They specifically designed that transmission for the ATS. I would find it hard to imagine they would regulate it in the ATS line to a single engine choice.
in my experience, GM likes to relegate the best for corvette and eventually trickle down the technology to other cars.
seeing as the 7 speed is brand new for the vette, I would be surprised if it founds it's way into the ATS.
mikesul
04-01-13, 10:36 AM
The seven speed is also a rear transaxle, different than an engine mounted tranny.
rand49er
04-01-13, 03:38 PM
The seven speed is also a rear transaxle, different than an engine mounted tranny.In that case, I would rather doubt the ATS has been designed to accommodate a transaxle ... though I might be wrong.
cztrammell
04-04-13, 11:06 AM
I dont think it's wrong to expect a Tremec. Aside from the C7. I do believe the current CTS-V also carries a Tremec tranny as well.
JFJr
04-05-13, 04:51 PM
The TR 6060 was in the C6 before the V2 came out with it as a choice, so ...
Jud
M5eater
05-05-13, 01:47 PM
Jud
It was also in a half-dozen other traditional longitudinal rear drive cars before it was in the C6.
