: Starter removal
03-28-13, 03:11 PM
Just wondering how much of a job it is to remove the starter in our "V". I want to change the lower pulley so I need access to the flywheel. I what to know what I'm getting into before I attempt the task. I will be changing the inter cooler at the same time.
03-28-13, 11:46 PM
Don't bother with it. I have an auto, and popped the bolt loose with an impact wrench easy enough. If you HAVE to, then go for it, but you should't need to.
03-29-13, 12:47 PM
Thanks for the info on removal. What about applying the correct torque on install? Any Issues?
