View Full Version : Any success programming keyfob for 03 Escalade EXT?
mel-
03-27-13, 04:03 PM
Hi,
I just bought a 2003 Escalade EXT. It came with one automate keyfob that worked. I bought another one online and need to get that programmed.
I tried contacting my local cadillac dealer and they said they could only program Gm keyfobs.
I searched on the forums here and found instructions for the 2003 Escalade but they did not work ;( I tried several times.
I have called around to all of my area locksmiths and so far I have found none at all that do programming ! I am just outside the Indpls area.
Has anyone had any luck programming one for this model and could you give me a link to instructions? Like I said, I did try instructions from the forums.
Or, if anyone is in the Indy area, do you know a locksmith able to program them?
Thank you in advance for your time,
Melinda
YoshiMan
03-27-13, 04:37 PM
I bought one of the FOBs from ace hardware and the instructions worked for my 03' ESV Here's their instructions:
OBP Instructions GM-4
Important: All remotes for vehicle must be present at time of programming. Remotes not present will become inoperable.
1-Enter the vehicle and close all doors.
2-Insert key into the ignition (do not start engine).
3-Press and hold the UNLOCK button on the driver side door.
4-Quickly, turn the key in the ignition to the ON position (do not start engine) and then turn key to OFF two times.
5-Release the UNLOCK button. The vehicle will lock and unlock the doors automatically.
6-Press and hold down the LOCK and UNLOCK buttons together on the remote until the door locks and unlocks. (This could take up to 30 seconds.)
7-Repeat step 6 for each additional remote.
8- Turn the ignition switch to the ON position in order to exit programming mode.
9-Remove the ignition key. Verify each remote has been successfully programmed.
mel-
03-27-13, 07:53 PM
thanks for that. those are the instructions I found here in the forums and I just can't get them to work (just went out and tried again).
it does seem to go into programming mode and out of it at the end.
I did take the working fob far far away so it wouldnt get screwed up. I was afraid I would end up with none working :(
I just ordered a genuine gm one so maybe that one will work. darn.
I did finally find a place that does them. they want $99 per remote and $31 per key (I only received one). wow. think I'll try some more calling around before paying that (and my keys don't have the chip so don't need their service at that price).
I think I'll call my local gm dealer to see if they can program this automate one and at what price. I don't think cadillac was right in that they couldn't as it looks like looking around the net that shouldn't be true.
thanks again.
Melinda
the cadillac man
03-27-13, 07:57 PM
thanks again.
Melinda
Any gm dealer can program a remote and the key can be ordered the same way a lot cheaper then a caddy dealer
mel-
03-27-13, 08:10 PM
thanks ! I will give them a call tomorrow. probably wait until this third fob comes in to have them all programmed together. frustrating. I just wanted an extra one in case I lose the original.
the cadillac man
03-27-13, 08:38 PM
Your welcome FYI they can program the remotes with the tech-2 which is easier and quicker
mel-
03-30-13, 08:35 PM
just to update:
I receive the gm brand new remote. the one that came with the truck was an automate and I bought a used one exactly like it.
the gm brand I was able to program with the instructions (same as posted above). still cannot get the second automate to program so even though the green light on it blinks when you push a button it must be defective. need to decide whether to bother to return it or not (was cheap used bought online).
one more question if anyone knows:
when I put the alarm button on the automate (original) remote, the horn blinks a couple of times and thats about all
when I push the alarm button on the new gm brand remote there is all kinds of racket sounding like a police siren amongst other sounds.
any idea why one remote triggers that and the other doesn't?
thanks again.
the cadillac man
03-30-13, 11:26 PM
just to update:
thanks again.
The automate remote works a alarm that is not controlled by the gm remote
mel-
03-31-13, 04:54 PM
thanks! is that siren like alarm the system that came with the cadillac or has it had another system installed? is there anyway for me to tell easily? looking under the hood or some box inside the truck? it's really annoying. the truck came from new york but I am in Indiana on a farm and my closest neighbor is half a mile away. no real crime here to need that kind of alarm (though I did have a subaru stolen right out of my drive I had left the keys in it we have so little crime !)
the cadillac man
03-31-13, 07:14 PM
Most alarm systems are installed inside the vehicle and should be obvious
Pitbull14218
03-31-13, 09:24 PM
Where's the best place to get a replacement fob? I need one I currently use the key to unlock :(
the cadillac man
03-31-13, 09:26 PM
You have to find out the brand of the alarm system and order one through the company or online if you have then part number
Pitbull14218
04-02-13, 09:07 PM
I'm talking just a factory key fob for my stock 02 escalade, doesn't have an aftermarket alarm at all.
the cadillac man
04-03-13, 02:01 AM
Oops I have the reprogramming steps on my laptop i will post them tomorrow for you
Pitbull14218
04-06-13, 06:06 PM
I mean, I don't have an actual key fob, I bought my truck and it only came with the ignition/door key, so I want to buy a fob but as cheaply as I can, and then program it to my truck. I just don't know where the best place to find a key fob for my 02 Escalade is. Any recommendations? Then ill need help programming it.
Pitbull14218
04-26-13, 07:44 AM
So where is the cheapest place to get an OEM Keyfob?
the cadillac man
04-26-13, 04:53 PM
A dealer will program it for you if you get one through a gm dealer
