: 1983 Cadillac 2 door Brougham pinion seal leaking
caddy1983
03-22-13, 07:54 PM
Dealer does not carry this part anymore. I need a OEM type of pinion seal. Any aftermarket seals you recommend. How are
the seals at autozone,pep boys,napa, or orilleys. What type of gear oil will you recommend(the weight)? should i go with
synthetic, standard gear oil or both mixture. Should I use an additive. Thanks
The Ape Man
03-22-13, 10:11 PM
How bad does it leak? If it is only a stain or a weep just top off the gear lube with type mentioned in Cadillac manual included with car.
Replacing a pinion seal requires very careful retorquing of pinion nut. Too much tension and the gear depth becomes destructive. I've seen this happen with unseasoned mek-a-niks eager to make a few bux stopping an inconsequential leak.
jayoldschool
03-22-13, 10:14 PM
I've used both AC Delco and Dorman service yokes/seals.. Both are fine, and stopped the leak. 80w90 gear oil, with one bottle of GM posi additive if you have posi (and you likely don't).
The Ape Man
03-22-13, 10:23 PM
A 4.1 with a posi? Hahahahahahah!
jayoldschool
03-22-13, 11:21 PM
Come on, it could spin the tires! On ice. If you did a combination brake stand/trans drop.
The Ape Man
03-23-13, 12:18 AM
And some N2O. Bring a broom and dustpan. Maybe some speedy dry.
