View Full Version : 18" track package wheel setup
the blur
03-21-13, 06:22 AM
Let's say I get the 18" track package wheels. What size tires do you guys run (staggered sedan)?
I see nothing close to the OEM 27" diameter.
The car will remain stock, other that tires and brake pads for the track.
cruiser68
03-21-13, 06:57 AM
I run 275/35R18 in all four corners
the blur
03-21-13, 10:16 AM
So your running 1.5" less OD on track? The OEM OD is 27" That doesn't affect anything?? (besides the speedo.)
cruiser68
03-21-13, 07:48 PM
No issues other than speedo slightly off.
Low_ET
03-21-13, 10:04 PM
I run 275/40/18 at the track. The speedometer is 0.6 mph off stock at 60 mph (measured). No issues with tires.
I use OEM brake pads at the track. They are Ferodo pads made for Brembo and sold by AC Delco (All three names are on the box). I like the stock pads because you don't have to bed them to the rotors.
the blur
03-22-13, 12:43 AM
What size tires to you run up front? I'm looking for a staggered setup. Even if the car pushes a little bit.
thebigjimsho
03-22-13, 01:40 AM
If you track a lot, a square setup is best. 18" TSWs with 275/35 18 slicks are cheap and plentiful when found used. You can rotate them easily and the V will get more front tire, which it will like. 275 slicks are as wide as 285 streets and will give you plenty of grip on the track.
I know your brain is forming opinions and ideas. Just do what we do and enjoy it!
Low_ET
03-22-13, 07:47 AM
I run 275/40/18 on 18x9.5-40 mm offset wheels on the front. A 285/40/18 will fit fine but it is an uncommon size. 295/35/18 is readily available, but I haven't tried it.
On the stock wheels, you can fit 275/30/19 (front) and 305/30/19 (rear).
Some people who track their CTS-V use 295/30/19 on the front and rear. That size is only available in a race tire.
cruiser68
03-22-13, 09:42 AM
Yeah, what jim said :)
VSGLS1
03-23-13, 08:02 PM
What wheels are you running at the track?
the blur
03-23-13, 08:09 PM
My club just made a rule. No R tires and R pads without 5points, harness bar, and proper seats.
Low_ET
03-24-13, 08:52 AM
TSW Nurburgring 18x9.5 - 40 mm offset. The same as many forum members use.
Most 18" wheels don't clear our front brake calipers. The Nurburgring design provides adequate brake caliper clearance.
cruiser68
03-24-13, 08:59 AM
Same wheels here. Pretty light too.
Ssteve
03-26-13, 04:22 PM
Can you guys throw some pics up please?
NAX-121
03-26-13, 05:11 PM
I run 18x10 Team Dynamics Pro Race 2.0 wheels with Hankook Ventus RS-3's. Theses wheels are spec built for V2's.
105722
Low_ET
03-27-13, 08:07 PM
TSW Nurburgring wheels come in black, bronze, and silver. Mine are bronze just because I needed them in a hurry for a track event and that was all I could get from local stock. The silver ones look a lot like the factory CTS-V wheels.
105798
