: 2000 Escalade HELP!
SpeedinBitch
03-20-13, 12:58 AM
This afternoon I was on the freeway and all of the sudden it became sluggish then a few minutes later the check engine light comes on so as soon as I got off the freeway it just died. I checked all gauges as soon as I saw the check engine light on but nothing was out of the ordinary. So shortly after it died I noticed smoke coming out from under the hood. I just replaced my radiator roughly a week ago and had no issues. So long story short now there is water in the oil. Could this be a blown head gasket, cracked head, or block by chance? Any advice would be great.
the cadillac man
03-20-13, 01:13 AM
If the tail pipe smoke is white or smells sweet then it might the gasket ,or a crack in the head or block
First you need to get the codes since the engine light is on
djais1801
03-20-13, 09:55 AM
why did you replace the radiator...was it because of a previous overheating? if so, maybe the heads got warped
SpeedinBitch
03-20-13, 11:45 AM
I didn't see any smoke coming out of the tail pipe when this incident occurred, however I am unable to get it started and take it to get tested to see what codes come up :\ The only smoke or steam was coming from under the hood starting from the battery to where the overflow container is.
I replaced the radiator because there was a nasty muddy substance in the radiator. I have never had any over heating issues previously.
the cadillac man
03-20-13, 11:48 AM
Will the truck not crank?
If not you may have to borrow a code scanner
SpeedinBitch
03-20-13, 11:56 AM
Yes it will crank but it wont start when I crank it over it doesn't sound normal if that makes any sense.
6lbsofSound
03-20-13, 12:18 PM
Sounds like it overheated and you may need new head gaskets. I wonder if the previous owner just dumped bars leak or something similar to cover up the problem.
the cadillac man
03-20-13, 02:56 PM
I agree
