: Memory seat
pa2wheelrider
03-19-13, 09:56 PM
Just picked up my ATS Saturday, The salesperson's product knowledge was terrible. he showed me how to program the easy
exit drivers seat but when i get in the car it stays in the back position. I have to press and hold memory 1 for the seat to go back to my driver position, I can use any help you can give, thanks
Bob
pever
03-19-13, 10:05 PM
The seat can be set to move when a) you open the door, or b) when you start the car (not the remote, just the ignition). The remote interacts differently and so does OnStar and so does it depend on which remote fob was last in the car relative to the OnStar remote start - I think. Also, have you also set Personalized Settings on?
pa2wheelrider
03-19-13, 10:16 PM
Yes personalized setting is on, when i turn the car off and open the door the seat goes back to let me exit, but when i get back in and start the car the seat stays in the exit position
hood101010
03-19-13, 11:29 PM
I had the same problem. There is an update for it. It is connected with the reverse mirror tilt problem. Have you tried the mirror tilt? Try that and if that has issues as well you probably need the update. After I got the update ive had no issues.
pa2wheelrider
03-20-13, 07:01 AM
Yes i have the tilt in reverse function and its working fine, Also i may ad the dealer installed the latest software the day before i picked up the car.
Cadillac Cust Svc
03-20-13, 04:58 PM
Pa2wheelrider, I see that you're engaged with forum members and wanted to let you know I'm available if you have any lingering concerns along the way. I'm sorry you were experiencing these frustrations, and please contact me anytime if you would like me to document your dealer feedback or investigate further. I'm reachable via email at Katie_Lucille@gmexpert.com.
Best,
Katie
Cadillac Customer Service
rustybear3
03-23-13, 09:13 PM
If you got the memory seat update, the memory "set" procedure changes. Instead of holding the set button and pressing 1 or 2 of your memory buttons, you must now push set.....release.....then push button 1 or 2 until you hear the beep. You no longer hold both set and your memory buttons together. Also make sure you have memory recall to on in your personalized settings. I had this same problem until a fellow poster alerted me to the change.
pa2wheelrider
03-25-13, 10:02 AM
Thank you very much
moshe-sz
06-01-13, 04:59 AM
If anyone can help. Had new seat software loaded by the dealer in Israel. All is programmed correctly. Now seat doesn't move to memory position at door open or ignition key on. Only after pressing 1 or 2 memory keys?
Moshe
Moshe
Lorne
06-02-13, 12:24 PM
Moshe,
That's the way the seats are set up -- you have to hold the button down each time you want to change seat position. I recommend not setting an exit seat position if it's not necessary.
MASCAD
06-02-13, 01:19 PM
Moshe,
That's the way the seats are set up -- you have to hold the butkey fob positionton down each time you want to change seat position. I recommend not setting an exit seat position if it's not necessary.
The seat should move to the correct key fob position either upon opening the door or engaging the start button depending on how it is setup in CUE. Also the seat should move to either #1 or #2 position if you just lightly tap the button. If you hold the button fully down the you will have to keep if depressed until the seat gets to the correct position. The seat will also stop moving if the button is released from the fully depressed position. This is the correct function of the seat and if it isn't working this way there is a problem in the system. Could be a software issue or maybe a defected switch or ???
torkibe
06-04-13, 08:54 PM
IF the car is on and in park, that is how it is intended to function. Any other combo and you must hold the button.
Also, there are threads discussing these various issues ad nauseum.
MASCAD
06-04-13, 09:30 PM
Very true in both cases! Don't want to have the seat, mirrors and possibly the steering wheel move while the vehicle is in motion due to accidental contact with the button.
flycaster
06-05-13, 09:49 AM
I can just about force myself to understand Caddy's safety concerns with having the seats/mirrors accidentally move while the car is in motion; however, I feel that they have caused more issues with the way they have approached this "perceived" problem. Just look at the confusion about how the seat buttons work: Car in park, car in drive, car not on, car on...hold button, tap button...too many combination...give me a break...I don't believe that any other car manufacture has gone to these contorted lengths to satisfy those few incompetents who may be "fumbling" (would have to be a fumbling incompetent as who would believe that one would accidentally hit the set buttons) with the seat setting buttons. With these ridiculous seat setting machinations, Caddy may have actually decreased safety conditions in that right now there probably are many new owners out there that are fumbling around with their seat setting as they are driving. Come on Caddy, you can easily reprogram so that the ATS seat setting will be as we are used to having: Regardless of the the car's operating mode: Tap Set, tap 1 or 2 to set seat position. Tap 1 or 2 to position personal seat setting. BTW, with all this holding of the button while driving, didn't Cadd yconsider that the driver is now driving with one hand???
moshe-sz
07-09-13, 06:36 PM
Moshe,
Thanks a lot. It is strange. If the CUE allows you to program set to seat memory, for example at ignition on, so why the seat is not going into memory position? And only after holding the #1 button? It doesn't make sense!. I had a CTS before and all functioned correctly. The dealer in Israel doesn't know how to correct and is talking to GM. It actually happen after software upgrade done. Before it worked, but had other problem of not allowing to program a new seat position memory.
Can anyone help?
Thanks,
Moshe
drye
03-07-14, 03:33 PM
Glad I stumbled onto this post. I was getting frustrated trying to get the memory settings for the seat working!
Thanks
NickAts
03-09-14, 12:40 AM
I had that same thing happen when I got in my ATS the other day. The seat would not go to it's #1 setting when I started the car. I had to press the #1 memory button to get the seat to get into my settings. After a few hours and beers I realized that I took the other key fob that time. The seat is programed to each fob separately. When I used the other fob it worked like normal. That was why the salesman told me to program both #1 and #2 buttons and I only programed #1.
flycaster
03-09-14, 10:30 AM
Quite right, RB3, after the update one must press the Set, release it, and then press the numbered button until the beep. But to add to the strange working of these computer controlled cars, here's how mine works. Had the update a while ago: First Set then numbered button until beep. However, somewhere along the line car reverted back to its pre-update mode. Nonetheless, all seat settings (including Exit) and mirror memory functions work as they should even though I now have to hold both buttons simultaneously. Haven't reported it to my SA as I've been there enough and things are working fine.
Shooter2384
03-17-14, 11:02 AM
I just picked up my ATS on Friday. I was aggravated all weekend because the seat was not going to memory position 1 when I opened the door. After some research I found the the memory location is linked to the key fob in the order the key fobs were programmed to the car. Switching key fobs was the answer.
Adex
11-04-16, 09:50 PM
Change the mirror tilt setting ....setup you mirrors and seat to a desired position....press 1..or 2.. than SET after the beep! Your fob should be set to remember this setting. have this set to ignition on..will give you enough room to get in, and the seat will get into place when you start the car... should work well from there!
CaptSoloNJ
11-06-16, 10:57 AM
I know this may sound counter-intuitive, but I hope you can read pages 3-6 and 3-7 of the Owner's Manual?
or did some of the instructions change?
