: EXIT seat settings
wetneck
03-19-13, 08:34 PM
03 EXT
have the seat settings/presets set up fine but it there any way to adjust the EXIT position ? not on key out or door open but the exit
position....
jjtwomey
03-19-13, 08:57 PM
03 EXT
position....
It should just like setting up the seat position 1 and 2
Get the seat in the position you want and then hold down the exit button until you hear the chimes... And every time you tap the button it will go to that position
the cadillac man
03-19-13, 09:37 PM
03 EXT
position....
There should be a setting in the personalization setting using the steering wheel controls
It's labeled easy exit seat or something like that
Most likely it has been turned off(most dealers turn it off to prevent someone possibly getting pushed into the steering wheel (I had this happen to a body shop worker who hopped in my truck before I could tell him to use the driver 2 preset
I did get a laugh from it though luckily I knew the guy or I would had some explaining to do
