: what gear oil are you using?
djais1801
03-18-13, 06:41 PM
i replaced my front/rear and transfer case oil with Amsoil severe gear on my 03 EXT...and used Royal Purple on my 08 Wrangler Sahara..both were good...
anyone else have comments or different choice? My rig just hit 100,000 mile mark, and am planning the 100k tune up...and change the driveshaft oils.
6lbsofSound
03-18-13, 09:23 PM
Royal purple,amsoil,mobile 1,redline they are all good and exceed OE specs. No need for a friction modifier as they all include it.
It's just a matter of personal preference.
Fox2boost
03-20-13, 10:28 PM
Just changed alliance to royal purple.
Fox2boost
03-20-13, 10:28 PM
All mine*^
godsdiablo
03-21-13, 08:26 AM
What weight did you use?
Fox2boost
03-21-13, 08:52 AM
Max gear 75-90w for the front and rear diffs and there ATF for the transfer case. The right stuff silicone for the rear end cover. Gaskets always leak. Be clean and the right silicone is your Freind.
djais1801
03-21-13, 04:08 PM
Max gear 75-90w for the front and rear diffs and there ATF for the transfer case. The right stuff silicone for the rear end cover. Gaskets always leak. Be clean and the right silicone is your Freind. exactly!
