: EFI to Carb swap ? - 1976 Eldorado
davidp1561
03-18-13, 05:59 PM
I have a 1976 Eldordo with factory EFI. Am curious to know what the expert opinions may be on if the EFI should be swapped for a carburator? How reliable are the old EFI's and how available are EFI parts etc?
Submariner409
03-18-13, 07:05 PM
Hang tight - which engine are we talking about ??? (500, 472, 425 ???) If you get no answers here we can move this to the Engines forums.
Welcome Aboard !!! :highfive:
davidp1561
03-26-13, 06:05 PM
Thanks for the welcome am looking forward to being part of the fun. The engine is the 500 cid................
basscatt
03-26-13, 07:26 PM
the original EFI system was SO bad - they made a carb-swap kit -
and the vast majority did the swap -
if you LOVE to tinker - and REALLY ENJOY being frustrated -
stay with the EFI -
if - on the other hand - you would rather go for a nice - relaxing cruise -
put the carb on it -
Submariner409
03-26-13, 07:27 PM
OK - The general trend here in Seville/Eldorado is the Northstar engine. Let me move this to Engines, 500 etc., and see what happens.
cadillac_al
03-26-13, 08:04 PM
stay with the EFI -
That's been my experience too. If the FI worked, I would run it as long as it worked good. Replacement parts are hard to come by though. I don't think I would trust it for a cross country trip either.
The Ape Man
03-26-13, 09:10 PM
My opinion is the carb cars never even came close to running as well as the injected Cadillac 500 or 425. They do take knowledge to keep running though.
I would sooner switch to a more modern injection like a Megasquirt than put a toilet bowl on top of the intake manifold.
If you are anywhere near Toms River NJ I'd be glad to take all those awful injection parts off your hands in exchange for installing the carby/intake/misc stuff.
drmenard
03-26-13, 09:42 PM
The main problem with those old computers are they are old.. They say the parts are hard to come by, but I have a bunch of them.. There is a member of this board , Bruce Roe, that fixes the computers and some mods to keep them running with less problems... If I had your car I would just keep some spare parts on hand, like a spare computer and a few temp sensors.. I would take out the low pressure fuel pump in the tank and put in a high pressure pump.. That way you can take off the high pressure on the frame and just use one pump... And do Bruce's extra relay mod to run the pump to help save the computer...The only part that is hard to find is the fast idle heater valve... I had a lot of them , but there all gone now...
The Ape Man
03-27-13, 08:20 PM
Good info. The 500 C.I. fuel computer is not as easy as the 350 or 425 to come by in my experience. Agree on the pump. The other liability is the fuel lines.
I'm fairly sure someone could adapt an external fast idle valve like some of the Euro Bosch EFI cars of the era used. Probably been done already.
drmenard
03-27-13, 10:55 PM
Apeman... I have a used 500 computer that has been gone over by Bruce that looks the day it was made... Somebody will need it one of these days... I have a fuel injection set-up on a 472 run by a haltech... I made a fast idle replacement set-up... It is a solenoid valve that is closed by a timer circuit board and the haltech at a temp.. It closes when it reaches 150 F or if it is already warm it fast idles for 60 seconds...
The Ape Man
03-28-13, 07:38 AM
Farout. Any details of pix of the Haltech?
drmenard
03-28-13, 11:04 PM
I will be taken it out of storage sometime real soon for the summer.. The first week of april is pretty safe no more snow.. I'll take some pictures and post them then...
The Ape Man
03-29-13, 07:54 PM
OK. I have to shoot some pictures for this site myself. Have to move the rocket launcher parts out of the way first.
caddydaddy
03-30-13, 10:10 PM
I agree! I had a '76 EFI Fleetwood and it was the smoothest running Cadillac I've ever owned.
The Ape Man
03-31-13, 10:53 AM
Especially at or just above idle. The uphill intake manifold on these engines may be the culprit.
When tuned for maximum economy 425s and 500s are not the best idling engines. Injection fixes this.
The major problem with that system was Cadillac didn't include a free shop manual with every one. The average mek-a-nik at the time could have very well have been seeing this as the first injection system ever in their shop.
BRUCE ROE
03-31-13, 06:26 PM
The 76-79 EFI book you really want is on EB*Y a lot, like Item number:330668089237. I
have a couple spares too, cover smudged some. I also have seen the 500 ECU listed.
Though, the 350 ECU can be retuned as a backup (wrong brackets). I should put how to
do that on my PHOTOBUCKET. Bruce Roe
davidp1561
04-04-13, 10:44 AM
yes i have ordered the efi diagnostic book. glad for the info tho you guys are great.
f_zechetti
07-10-13, 10:35 PM
Hi, here in Brazil I have a 76 Eldorado EFI and tired of trying to fix the fuel injection source. I installed the FuelTech, which is a programmable fuel injection and had no more problems. All original parts have been exploited and appearance of the engine remained the same. For the 500 engine, the fuel injection models used are the FT 300, FT350 and FT400
Not cheap, but solved my problems.
Manufacturer's website http://www.fueltechems.com/home.html
BRUCE ROE
07-11-13, 02:47 AM
Hi, here in Brazil I have a 76 Eldorado EFI and tired of trying to fix the fuel injection source. I installed the FuelTech, which is a programmable fuel injection and had no more problems. All original parts have been exploited and appearance of the engine remained the same. For the 500 engine, the fuel injection models used are the FT 300, FT350 and FT400. Not cheap, but solved my problems.
Did you use the same injectors at the same pressure? Still bank injection, or change to sequential? The same ignition, or an ECU programmed advance? Did you change the temperature sensors? How long did it take to get everything tuned up? Did you use an OX sensor? Did you change the idle air motor? Is your old ECU available for another Cad owner? Bruce Roe
f_zechetti
02-14-14, 02:42 PM
Everything remains the original, except for the replacement of TPS, temperature sensor, idle air valve and coil. Hall sensor was adapted in the original distributor (before has a mallory distibuidor was installed but did not work out). The mechanic took about 3 weeks to deliver the car. Yes, I installed the O2 sensor. The original ECU I do not intend to sell. You should also install a Peak and Hold and Spark Pro 1
Sorry for the delay in answering and the errors in your language.
185601
185609
185617
185625
185633
f_zechetti
02-14-14, 02:54 PM
The ECU was installed underneath: Car dashboard and tells you in real time various data such as engine temp, air temp, opening time of the injectors, etc..
185649
There is two other versions with touch screen, the FT 350 which has the same functions of the FT 300 and FT 400 which is the most complete.
185657
BRUCE ROE
02-14-14, 11:39 PM
Thanks for the pictures. Looks like the old wiring was redone for a new computer? That would imply you
are still using bank injection, not sequential? And a different cold idle air valve? Bruce Roe
ShedOfRedemption
11-03-15, 02:34 PM
Hi! any bode can tell me what i need to swap on carb in my caddi 77 425 efi ?? What carb ? and what other parts ?? please help!
caddydaddy
11-05-15, 09:39 PM
Just a Q-Jet off of a '77-'79 425 should work fine.
ShedOfRedemption
11-06-15, 02:38 PM
Thank you caddydaddy, i need something more to completly swap?? intake mainfold ?? some ignition moduje etc?? cheers
caddydaddy
11-07-15, 06:17 PM
I think the carb should bolt to the EFI intake manifold, but you'd need to install a fuel pump from a carbureted engine, since the in tank pump would have too much pressure. I'm not sure if the EFI distributor would work, but a swap to one from a carb'd engine is an easy fix.
