: 71 & 05 deville rim compatabilty
elespee
03-14-13, 04:42 PM
hi all!
wondering if id be able to fit a set of 17" '05 deville rims onto my '71 deville without messing anything up too bad. thanks in advance!
elespee
03-14-13, 04:43 PM
hi all!
stoveguyy
03-15-13, 09:23 AM
Think the 71 has old school bolt pattern? 5x4.75 or even 5x5"? The newer fwd stuff is 5x115mm or 4.52"
brougham
03-15-13, 12:26 PM
The bolt pattern is different and so is backspacing.
stoveguyy
03-15-13, 03:01 PM
Ya, there weren't a whole lot of cool alloy wheels in 71.
kntharty
03-17-13, 07:30 PM
Should be able to but you would have to buy adapters cause the lug patterns are different and you will have to play around with the thickness of the adapter.
Submariner409
03-18-13, 09:54 AM
Different lug patterns, different wheel offset, the '05 Deville wheels index on the center bore, not the bolt pattern. The Hollander master wheel interchange manual says NO.
elespee
03-21-13, 05:36 PM
does The Hollander master wheel interchange manual say they would fit on a '92 fleetwood?
elespee
03-21-13, 05:37 PM
would they work on a '92 fleetwood?
stoveguyy
03-22-13, 10:21 AM
92 FW is 5x5. 05 deville is 5x115
kntharty
03-24-13, 01:11 PM
Fleetwood brougham rwd or fleetwood 60 special fwd? Fwd: maybe-probably rwd: not without adapter if at all
