: Free 2005 cts-v wiring diagrams.
onebadcadi
03-12-13, 06:48 AM
I recently acquired these. this is everything for wiring on the 2005 CTS-V. i will try to get the other years too . but im sure that they havent changed much. I hope everyone can enjoy/use these as much as i do. maybe sticky this .... thanks
onebadcadi
03-12-13, 06:51 AM
moarrrr
onebadcadi
03-12-13, 06:52 AM
page 3
onebadcadi
03-12-13, 06:54 AM
page 4
onebadcadi
03-12-13, 07:00 AM
welp . looks like i hit my capacity on attatchments. does a supporting member want to post the rest of the wiring diagrams for me? its like 32 more files . and 1.40 mb in size .
Rez Rider
09-30-13, 09:37 PM
I'm new on this forum, and was looking for some diagrams. Forgive me but I don't see anything here. Do you still have them?
onebadcadi
10-01-13, 10:48 AM
Ya i do , what do you need?
Rez Rider
10-04-13, 09:04 PM
sorry for late response. I have a parasitic drain on my battery of my 05 CTS-V. I narrowed it down to the audio system. I know this because I pulled the 10 amp "audio" fuse in the L-REAR fuse box and the amp drain went from 2.3A to 1.7A. Then after about 30 seconds it dropped to zero. I need to know what is all on this circuit so I can try and find the culprit. Thanks in advance!
67+05CaddyV
10-19-13, 10:49 AM
I'm looking for the 05 door wiring diagrams - if you have em! thankx,
CTSVBIGGIE
11-21-13, 11:07 AM
Is there a way you could send these to me?
Scott2012
11-21-13, 11:07 PM
I'd like 05 and if you also have 2010 cts that would be awesome!
Lbar
05-17-14, 02:06 AM
Where the hell are the attachments?
TF Eftusk
06-04-14, 04:41 PM
My sediments exactly.
RNation0001
07-02-14, 09:06 PM
Can you email them to me at RNation0001@gmail.com
ta88gta
08-28-14, 03:08 PM
Sent you a pm requesting some diagrams
MrMagooslrc
09-22-14, 05:34 PM
Hi i need ecu wiring piouts im doing a 3.6 engine swap into a rx8 and need to build the stand alone wiring harness ,,,help would be greatly apreciated
Its a 2004 cts ,2005 should be similar
NettNett
10-14-15, 03:36 PM
Can I get the wiring diagram on 05 cts needing to know all my speaker wires and stuff that's running thru the trunk thank you
Cadillac5.0L
10-16-15, 08:24 PM
Hi, onebadcadi
Do you still have these wiring diagrams. If so would you mind emailing them to me
bkaaye47 at outlook.com. Could not find your attachments. I have a 2005 CTS 3.6
Many Thanks.
Attos
12-13-15, 05:51 PM
Hi there, I cannot see any wiring diagrams in here. Any trick to display them? Working on my 2005 CTS which does not seem to start. It all of a sudden decided to quit responding to the ignition switch. Replaced the switch with a new one but still the same thing.
darkman
12-13-15, 06:44 PM
The starting/charging wiring diagrams for the CTS-V can be found here:
http://www.cadillacforums.com/forums/2004-2007-cadillac-cts-v-general/796225-05-acting-like-dead-battery-start.html#post15122441
I do not know how much they differ from a CTS. On the CTS-V, if the starter "clicks" when the key is turned, but does not start, the issue is with the starter/solenoid. If there is no "click" is typically means the computer is withholding the necessary connection because the pre-start parameters (car in park, clutch depressed, coolant temp, etc) have not been met; or there is a problem with the wiring/connectors/grounds.
Lathedog
02-24-16, 12:42 PM
I am logged in and can't see wiring diagrams ..what do I need to do? My lot front side light is dim and causing the dash turn signal to illuminate.. Need help on the wires. It's the blue with white stripe that I am tracing. Thanks. Jim
darkman
02-24-16, 04:54 PM
See attached.
Are there aftermarket LEDs on this car?
Lathedog
02-24-16, 05:45 PM
Thanks Darkman!
Yes,I replaced all the bulbs with LEDs... Shit. Suppose that's the problem? Jim
darkman
02-24-16, 05:54 PM
Thanks Darkman!
The LEDs have less resistance than regular bulbs and the flashers depend on a certain resistance level to work. The fix, I am told, is to add resistors to the circuit. I have not done LEDs but there are threads on the subject.
http://www.cadillacforums.com/forums/2004-2007-cadillac-cts-v-appearance/464274-alternative-led-turn-signal-hyper-flash.html
(http://www.cadillacforums.com/forums/2004-2007-cadillac-cts-v-appearance/464274-alternative-led-turn-signal-hyper-flash.html)http://www.cadillacforums.com/forums/2004-2007-cadillac-cts-v-appearance/188659-turn-signal-flash-rate-leds-installed.html
http://www.cadillacforums.com/forums/cadillac-cts-first-generation-forum-2003/288589-issues-led-smd-bulbs.html
http://www.cadillacforums.com/forums/2004-2007-cadillac-cts-v-appearance/180159-led-bulbs-tail-lights.html
And from Google:
https://www.superbrightleds.com/moreinfo/flashers-load-resistors/led-light-load-resistor-kit-led-turn-signal-hyper-flash-warning-fix/190/
Lathedog
02-24-16, 07:36 PM
Your the man Darkman! I owe you a few beers. I had the rear led not working..I replaced it and that's when I noticed the light on the dash. When I got out and looked at the lights I saw the front side lite dim so off on a wild goose chase I went! Spent a couple hrs on it today!!! Dang it. I went out and put a regular bulb in the rear turn signal and it fixed it. Thank you so much.. I'll read up on the posted threads so I can run the LEDs. They look nice on it. Cheers Darkman��
moaltairy
05-10-16, 11:53 PM
Still have these diagrams? Need the brake lights/abs/TC diagrams if you have em! Thanks! (moaltairy@yahoo.com)
willijr
03-26-17, 02:30 PM
Darkman,
I'm looking for wiring diagrams of the 2005 CTS, specifically the main ECU pinout. Thanks in advance if you can help!
2005 CTS British spec.
darkman
03-26-17, 06:38 PM
Darkman,
I do not have the wiring diagrams for the 2005 CTS. The ECU pin outs are engine-specific. I do not know whether, there are differences among the various engines for domestic (USA) versus export models.
willijr
03-28-17, 01:28 PM
No problem. Thanks for the quick reply. I found a website called AllDataDIY.com. It's a subscription service for an on-line service manual for nearly all makes of vehicles, including wiring diagrams.
