View Full Version : Question regarding spacer
Trionalaw
03-07-13, 08:57 AM
Iím installing 275/35/19 and 305/30/19 on my stock wheels on my 2012 CTS V Coupe. I understand spacers are recommended. I note I can get 11 mm for the front and 15 mm for the back. Some suggest running 15 mm all the way around.
I do not drag race the car. Rather, I take it to driving schools. Obviously, Iím looking for road course handling.
Any suggestions would be greatly appreciated.
Thanks so much,
Jim
Rule12b
03-11-13, 05:21 PM
I’m installing 275/35/19 and 305/30/19 on my stock wheels on my 2012 CTS V Coupe. I understand spacers are recommended. I note I can get 11 mm for the front and 15 mm for the back. Some suggest running 15 mm all the way around.
I do not drag race the car. Rather, I take it to driving schools. Obviously, I’m looking for road course handling.
Thanks so much,
Jim
So, as I mentioned in another thread. I run the OEM wheels but not precisely OEM set up. I widened the fronts and moved them to the rear, now 19x11. The rear OEM's I moved to the front. I run a fairly wide spacer on the rear (either 12 or 15 mm I think) and a smaller one up front (no idea). There is no rubbing, period. I'm only selling the complete set up because the car is getting set up for track-only duty. The handling is much improved with the bigger rubber.
Now, on stock OEM's, I was under the impression that you can run the sizes you mentioned without any issues, but again, I'm not an authority on that since I didn't try it. I have read I think a lot of posts with people running those sizes on OEM setups without issues.
Trionalaw
03-12-13, 10:20 AM
Thanks for your input. I ordered 15 mm spacers all the way around because I wanted to keep the same ratio between the front track and the rear track. Why? I don't know! Probably like what Emerson said in Self Reliance "A foolish consistency is the hobgoblin of little minds."
the blur
03-12-13, 11:56 PM
Do you need longer studs with the spacers ?
do you loose the hubcentric effect with spacers ?
will they clear without spacers ?
Rule12b
03-12-13, 11:59 PM
The spacers are hubcentric. Good question on studs I don't recall but can find out. I think they are stock but they may not be. No, my set up will definitely not clear without the spacers.
the blur
03-13-13, 12:04 AM
I just got my V, so I'm asking 10 zillion questions. I'm not looking for every tenth of a second, just looking for a solid track day setup. thanks
Rule12b
03-13-13, 12:57 AM
I just got my V, so I'm asking 10 zillion questions. I'm not looking for every tenth of a second, just looking for a solid track day setup. thanks Well then you are in the right place to ask 10 zillion questions. I'm happy to help. Just sorry you are East Coast so you can't hit a Challenge event with us out here. Ask away, lots of good info here.
thebigjimsho
03-13-13, 11:20 AM
If your spacers are small, stock studs would be fine. Beefier spacers should have longer studs...
hlantin
03-13-13, 12:10 PM
I ran 11mm spacers on my sedan, but I had longer studs. Not sure how much spacer you can run without needing longer studs? If you're going to a road course, might be worthing looking into getting longer studs if you're planning to run spacers.
I have 4 11mm spacers if any are looking for some...
Betiwin
03-16-13, 08:31 AM
If they are bolt in hubs centric spacers longer studs are not necessary. I run 15 MM all the way around. Your stock wheels have holes in the back to accommodate this.
the blur
03-16-13, 12:01 PM
A picture would probably help.
Rule12b
03-17-13, 09:01 PM
A picture would probably help. Well here is the OEM widened switch. . .
http://i2.photobucket.com/albums/y34/Rule12b/photo2-2.jpg
Trionalaw
03-19-13, 12:06 PM
Ordered the spacers from Motorsport Tech. Its owner assured me everything would work with the tires I have ordered. Spacers came in today. I will know Thursday when I take the car in to have the tires mounted.
I will report back and take some pictures.
Trionalaw
03-19-13, 02:43 PM
Rule12b
03-19-13, 03:17 PM
You will probably need longer studs.
