: Switching radios on my DTS.
kadylac1
03-03-13, 03:19 PM
I own a 2008 Cadillac DTS with a stock radio (top picture) and I want to switch to the navigation radio (bottom picture). Has anybody been able to do this conversion? Is this possible or just too much of a hassle?
--- P.S. - I have a Non-Bose system, thanks ---
104630
104631
big greg
03-03-13, 03:43 PM
I'm curious to this as well!
kadylac1
03-03-13, 03:50 PM
@BigGreg: Yeah it looks looks simple, but you never know.
phigment
03-03-13, 04:43 PM
I did this in my car. I believe the nav is only compatible with the Bose system but it is possible that I am wrong. The following link is for the nav system installed on a Buick Lucerne. The install for DTS is almost identical except the dash pieces are slightly different.
http://www.buickforums.com/forums/showthread.php?t=9509
I got my wiring harness(VSS wire), aftermarket antenna, and nav unit off of ebay. Also, you will have to have the unit programmed after you get it installed. You will get no sound until it is programmed.
kadylac1
03-03-13, 06:13 PM
@Phigment: Sweet, thanks for the info.
MoistCabbage
03-03-13, 08:29 PM
I got my wiring harness(VSS wire), aftermarket antenna, and nav unit off of ebay. Also, you will have to have the unit programmed after you get it installed. You will get no sound until it is programmed.Same deal with older Sevilles/Devilles. And the nav HU is Bose. Not compatible with non Bose systems.
grullon10
03-04-13, 12:49 AM
I went after market and look like it came with the car. Go ebay and a radio harness gm lan29 and a antenna adapter. I did my 4 years ago I bought a pionner 7 inche radio and it going to be more cheap. I am trying to downlow some photos of it but i haven't been able. tomorrow I will post the photos up
This is one of the adapter that it could be use http://www.crutchfield.com/p_120OSLAN02/GMOS-LAN-02-GM-Factory-Integration-Adapter.html here is another on http://www.ebay.com/itm/Cadillac-DTS-SRX-Radio-Dash-Mount-Installation-Kit-Harness-Antenna-PKG214-/270886343497?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A2008%7CMake%3ACadillac%7CModel%3ADTS&hash=item3f12159349&vxp=mtr
kadylac1
03-04-13, 02:55 AM
@MoistCabbage: Thanks for the verification on the Bose issue. Too bad, that navi unit looks clean.
@Grullon10: Sweet post, that looks like the best route to go. Thanks.
big greg
03-04-13, 08:45 AM
That's too bad
grullon10
03-04-13, 01:04 PM
Guys this is the way it look aftermarket it could be at bestbuy or any place that do car radio.
104680
104681
