: Rebuilding ls6 05 v
05 CTS-V LURKN
02-21-13, 01:31 PM
In about 2 weeks from now ill be rebuilding my ls6 from my 05 V. ill be posting up pictures on the process.
(is there anything i should know of that will make the job a bit easier before taking it out and ripping it apart,or should be prepared for)
(any tips or tricks)
REASON WHY; possibility of a spun rod bearing....
BTW IT WAS WORTH SMASHING ON A 2JZ SUPRA...
tommy compton
02-21-13, 03:06 PM
Transmission and engine come right out the top pretty easily. Hardest part is un hooking all the connections and moving the engine harness out of the way. Undo the AC compressor from the side of the block and leave it in the engine bay.
rand49er
02-21-13, 03:11 PM
Are you rebuilding it back in stock form? If not, then that opens the door to a million pieces of advice.
05 CTS-V LURKN
02-21-13, 03:39 PM
Transmission and engine come right out the top pretty easily. Hardest part is un hooking all the connections and moving the engine harness out of the way. Undo the AC compressor from the side of the block and leave it in the engine bay. thanks man really appreciate it, makes me less worryed now ..you you happen to know where I can get the torque specs for everything important?
Nah everything is stock, any recommendations on new rod bearing brands?
darkman
02-21-13, 04:20 PM
See attached. I would get a complete Service Manual if I doing that job. (See Helms, Inc.)
PISNUOFF
02-21-13, 04:46 PM
This book is worth its weight in gold. Leave the a/c compressor, A/C condenser and the power steering pump in the car.
http://www.amazon.com/gp/aw/d/193249460X/ref=redir_mdp_mobile
darkman
02-21-13, 05:33 PM
Thanks - I just order one for me.
05 CTS-V LURKN
02-21-13, 06:13 PM
sweet man thanks, im about to order it.
have you rebuilt one before?
FoD
02-21-13, 06:32 PM
PISNUOFF is the community product tester. He's broken them, rebuilt them, broken them again. Good luck with your rebuild!
