: My 05 Escalade is blowing cold air out of the driver side only
misscadillac
02-20-13, 03:41 PM
need some help.. my 05 escalade when the heat is on it is blowing cold air out of the drivers side and hot air is blowing out of the rest of the vents? can any one help and let me know what that might be?
the cadillac man
02-20-13, 04:49 PM
Try pulling the hvac fuse in the under hood box
If that don't work then the actuator will have to be accessed
On the passengers side bottom of the dash there is a access panel(commonly referred to as the kick panel) with three screws
Remove those and the panel removes
The actuator is held with two screws
misscadillac
02-20-13, 06:14 PM
ok thanks i will try that
misscadillac
02-20-13, 08:47 PM
Hi Cadillac man can u post it here it won't let me receive ur message
Can u post it here am new to this LOL it says my inbox is full? I deleted everything
the cadillac man
02-20-13, 09:08 PM
I posted the answer in your other thread
Cadillac Cust Svc
02-21-13, 10:12 AM
Any luck, misscadillac? Hope to hear back soon!
Sarah (Assisting Katie), Cadillac Customer Service
misscadillac
02-21-13, 01:48 PM
Yes got it fixed!!
the cadillac man
02-21-13, 02:46 PM
Yes got it fixed!!
That's great I am glad to help
misscadillac
02-21-13, 03:05 PM
The Cadillac man I didn't see a fuse under there that said sir in my book it says it the hvac 1 that's the one I pulled for tgw heat and it didn't work for the rear view mirror? Any other suggestions?
the cadillac man
02-21-13, 03:41 PM
There is a few fuses that work in with the mirror and its controls but the s.i.r fuse is one as it is listed in the gm service manual
misscadillac
02-21-13, 03:52 PM
OK I'll have to try some more i didn't see any s.I.r on the fuse pantles? Hhmm
the cadillac man
02-21-13, 04:02 PM
The s.i.r fuse is in the under hood fuse box
There is a few bcm fuses in the dash fuse block(drivers side end cap) that might work the mirror
I will look at the wiring diagrams I have and see where the fuse is and what the amp rating is
misscadillac
02-21-13, 04:24 PM
OK ya I didn't see any under the Hood with s.I.r LOL OK ya let me know if you find anything thanks
the cadillac man
02-21-13, 04:31 PM
Are there any lights on after you start the truck?
(Eg air bag light, abs light)
misscadillac
02-21-13, 04:40 PM
Nope no lights on...
the cadillac man
02-21-13, 05:18 PM
Maybe the mirror connection is loose try wiggling the harness on the back of the mirror
Also there should be two lights on the mirror one for the mirror one for the onstar system on the right
Along with a power button for the mirror and a light on the left
misscadillac
02-21-13, 05:29 PM
Hahah got it there is a power button lmao
pilot-werx
02-22-13, 04:13 PM
remove the plastic molding under the the passengers side dash to expose the blend actuators. you need to replace the actuator that is towards the center of the truck. just did mine a few weeks ago...
misscadillac
02-22-13, 04:47 PM
OK thanks
