: Installed Revshift Bushings today
05txctsv
02-20-13, 12:05 PM
Installed the Revshift trans bushing today. Nice to say it makes the shifts more precise and accurate.
The trans bushing looked like others i have seen and now this is what it looks like.
http://i816.photobucket.com/albums/zz82/stepoore/cts-v004_zps07271d94.jpg
Super easy to install, just spray trans mount with WD-40 and get a big flathead screwdriver or prybar.
wedge prybar on driveshaft bolt and pry it in, no problem.
Now the rear diff bushing involved more work. Removal of exhaust helped alot. Followed others instructions and
easy peasy. I even used the OEM kent tool (which is for sale for $45). Here are a couple of picks.
http://i816.photobucket.com/albums/zz82/stepoore/cts-v009_zpsc2e36f22.jpg
http://i816.photobucket.com/albums/zz82/stepoore/cts-v005_zps6789a49e.jpg
http://i816.photobucket.com/albums/zz82/stepoore/cts-v008_zpsa47534ed.jpg
Now here is the bushing i pulled out. once i got the tool on and started after a few turns this just fell out. doesnt look OEM.
http://i816.photobucket.com/albums/zz82/stepoore/cts-v002_zps66dce4d0.jpg
Any Ideas?
silentwig
02-20-13, 01:32 PM
The trans mount you replaced looks like a creative steel. Both bushings looked fine. I guess if the trans mount from revshift makes cleaner shifts, nice.
HAMSTAR
02-20-13, 01:46 PM
Diff bushing looks like Creative Steel. Do you notice a difference with the RS diff bushing?
05txctsv
02-20-13, 02:06 PM
diff bushing was loose and i could place back in by hand. it was not good. make a horrific bang when letting off gas in first or second and you can see that it was spinning in place. Now no bang and fun.
little bit better locating revere.
Motown Cad
02-20-13, 08:35 PM
Is this differential bushing what is causing that horrific bang? I had my friend drive car after we were done working on it and it scared the shit out of us. He was shifting fast with clutch and throw and boom. I guess we get used to it knowing how to shift to avoid that. But if this bushing eliminates that .....I'm in.
FuzzyLogic
02-20-13, 08:36 PM
If the bang came from the front...motor mounts. If it came from the rear, differential mount.
HAMSTAR
02-20-13, 08:56 PM
Could also be the stock flex disc that winds up and snaps back under high torque. The cure for it is the revshift guibo.
xbladr
02-21-13, 04:08 PM
Hamstar I get that... I have not wanted to mess with it though
Motown Cad
02-21-13, 07:33 PM
Sweet! Definitely from the rear. Thanks I'm in. These guys are in Warren, MI. maybe Rand or somebody could stop by when they're on that side of town.
kciaccio
02-22-13, 11:48 AM
Any Ideas?
Is this the tool?
http://www.ebay.com/itm/Kent-Moore-SPX-J-45007-Bushing-Remover-and-Installer-/360475432051
sssnake
02-22-13, 03:14 PM
So the stock flex disc contributes to the parade clunk? I'm about to do the clutch and pressure plate and want the recently developed clunk gone.
BTW I already have the CS diff bushing and block, RS trans mount, RS cradle mounts and TA mounts going in this weekend, RS motor mounts going in with headers - soon.
HAMSTAR
02-22-13, 03:18 PM
Not, not parade clunk. If you haven't experience that rubber-band snap-bang, I would leave the flex disc coupler alone. For me, it only occurs if accelerating hard out of a left turn in low gear when the back wheels slide a little then regain traction.
sssnake
02-22-13, 05:01 PM
Hmmm. Occasionally I get a series of surges when in low gear and coming out of a turn. I had assumed this was due to the motor mounts. I don't get any banging noise with this.
05txctsv
02-22-13, 08:09 PM
Is this the tool?
this is the tool that was in the box i purchased......dont know what that tool is
http://i816.photobucket.com/albums/zz82/stepoore/cts-v010_zpsfd853a74.jpg
when you gas it hard the suddenly let off gas, the loud clunk in back is what this fixed. Nice upgrade.
rguzman1
05-04-13, 04:40 PM
i having the same issues a clunk when i release the gas . or going up hill . rpm also drops . what should replace??
darkman
05-04-13, 04:45 PM
There are several possibilities, the most likely of which is the front differential bushing.
jeffao
08-17-13, 01:12 AM
How is the ride quality now that you've put these two revshift products in? I want to do the same, but I dont want to add any harshness or vibration to the ride.
