: Driver side washer fluid....EXT
Pitbull14218
02-19-13, 09:06 PM
Seems like my driver side washer fluid runs out first once I start getting low??? I have a 2002 EXT, anyone having his problem?
the cadillac man
02-19-13, 10:33 PM
Could be clogged on the spray nozzle as they should both work at the same pressure
Pitbull14218
02-19-13, 11:01 PM
Yeah idk I think when it gets low it only comes out passenger side. Ill have to fill it to see if the drivers side will work after I fill it
the cadillac man
02-19-13, 11:33 PM
If that don't do any good then the pump may be getting worn out
Pitbull14218
02-21-13, 05:01 PM
Yeah it didn't squirt out the drivers :(
the cadillac man
02-21-13, 05:33 PM
Check the hose coupler for the front washer the drivers side may have came loose or off
Pitbull14218
02-24-13, 02:45 PM
So the next day they both worked, seems intermittent. Is there two pumps, one for each squirter? Maybe one is going bad?
Also this winter I went through almost 4 gallons of washer fluid, I didn't see a leak but it seems like a lot to use for the winter.
the cadillac man
02-24-13, 02:59 PM
There is only one pump for the front and one for the rear most likely it is a hose issue
