View Full Version : 22s on 96 cadillac
benjam
02-19-13, 04:40 PM
Does anyone know if 22s will fit on my 96 cadillac sedan deville with out using a lift and if i do have to lift it does the air ride suspension have to be swapped out for regular suspension please help thanx
Submariner409
02-23-13, 03:43 PM
Your Deville does not have "air ride". It uses an Automatic Level Control to compensate for extra weight in the rear seat or trunk - defeat it and the rear sags. ALC/ELC is separate from the suspension control.
Let's say that your original tire size had a 27" outside diameter. As long as you keep that tire OD you can put any size wheel on the car and suffer no suspension problems as long as you're careful with treadwidth and section width to prevent fenderwell rubbing in turns.
Going to excessively large wheels creates a problem or two: With 16" wheels and a 27" tire OD there is 5.5" of air/rubber between the wheel and road. With 22's there is 2.5" of air/rubber between the wheel and the road: ride and handling suffer. Go to a larger OD tire to recover a bit of ride comfort and the larger tire diameter changes speedo readings, engine load management and transmission shift points.
Cadillac Kid03
02-27-13, 06:10 PM
Please don't put 22"'s on your Deville that's all. :D
