DopeStar 156
01-03-05, 12:42 AM
This morning when I went to start my 89 Brougham I encountered a problem. I got in, pumped the gas twice as usual and turned the key. The engine turned over but was weak and shaking. The engine sputtered for a few seconds and slowly stalled. I cranked it again and got no turn over. I pumped twice again and got the same result, this happened for three more attempts. Finally I tried again and proceeded to feed it gas by holding the pedal down. It was still sputtering but was running. I held the pedal for a few seconds and eventually the engine ran as usual.
A little scared but relieved that I started it, I stopped and filled up at a station about 10 miles away. I added some STP FI/Carb treatment to my gas after filling up to see if I can try to ungunk something that may have clogged. For the remainder of the day the engine started and ran as normal.
This isn't the first time I've experienced stalling and sputtering. Sometimes the car likes to sputter at this one intersection near my house, it would be the first stop/go intersection of my drive. It also sputters for a split second sometimes before the high idle at the first morning start up but after that split second begins the high idle as usual.
If you ask me I would guess fuel filter, since I never changed it and is most likely original with almost 123k on the clock. My other guess is the carb and that it may need a rebuild. Does anyone agree or disagree? Also with that problem this morning, did I handle it properly, or should I just have left it alone rather than fought it to start? Thanks.
