View Full Version : New Member and question on 1967 OEM wheels
V8der
02-19-13, 02:04 AM
Hello all,
I posted this in the RWD Deville section but after looking around i thought it may be better suited here. My name is Eric and i'm new to the forum. I have a 67 Sedan De ville that I have owned for about 11 years. Car is incredible shape and is my pride and joy! I recently have wanted to take the wire wheels off and put a set of stock steel wheels back on it with some 3 inch whitewalls. I have done some searches but haven't found anywhere i can locate a brand new set. Would anyone happen the know the best place to get a set? I know 15x5 is a pretty common steel wheel for a lot of cars but i want to make sure and get a set that will fit my factory hubcaps. any help i would appreciate! Below is some pics of my car.
http://i17.photobucket.com/albums/b83/mrfrozzay/cadside3.jpg
http://i17.photobucket.com/albums/b83/mrfrozzay/cadside2.jpg
http://i17.photobucket.com/albums/b83/mrfrozzay/cadside1.jpg
Dingo
02-19-13, 03:57 AM
Cool looking ride! I can't help you with the rims but with my limited photoshop skills I can roughly show you what it would look like with the stock wheels with a thin white wall...
http://i40.photobucket.com/albums/e202/DingosGotMyBaby/cadside3-1.jpg
V8der
02-19-13, 10:29 AM
that looks awesome! Thanks!
FoxRodder
02-19-13, 02:44 PM
I'm pretty sure they are 15X7. I've got what I was told was the original ones from my 68 sitting in the garage and was trying to decide if I should use them or not. Car came with nearly identical wheels mounted but painted red with a chrome trim ring. Can't ,make up my mind if I should paint the other set black before I get new tires. I think yours looks great with the wires.
Andrew224
02-19-13, 04:33 PM
You won't find brand new stock wheels for your '67, if by chance you do, they'll be priced sky high. Gonna need to make a lot of calls to junk yards. They shouldn't be too hard to find. For good used ones, you're looking at about $75 / piece, maybe less.
cadillacbart
02-19-13, 05:00 PM
Make sure you get stock steel wheels for a Cadillac. The way the stock hubcaps grip the rim is different than others.
Also if you have disk brakes in front, you'll need different rims.
cadillac kevin
02-19-13, 07:59 PM
Shouldn't rims from a rwd caddy up until 92 work? I know you can swap caddy hubcaps from different years on their steel rims.
mgil
02-21-13, 05:06 PM
I just found one on ebay they had the correct part , although a little pricey ,you might give them a try,@ allfactorywheels on ebay
FoxRodder
02-22-13, 12:19 PM
Just measured my 68 wheels and they are 7" outside lip to lip and inside where the tire actually seats I measured 6" so I'm assuming they are 15x6
jock82
03-05-13, 06:42 PM
The 1967 is one of my all time favorite Cadillacs, I love the styling. I had a 1970 coupe de ville, but I really like the vertical headlights on the 67.
