View Full Version : lights wont turn off
CISCO18
02-18-13, 10:13 PM
I have a 2003 escalade ext and recently my rear tail lights and my front running lights wont turn off all the fuses are good
the cadillac man
02-18-13, 10:32 PM
Is the headlight switch is the auto position?
CISCO18
02-19-13, 11:03 PM
the switch is completely on the off position there are no blow fuse lights are still on the truck now sit in my garage with the battery disconected
the cadillac man
02-20-13, 12:00 AM
Sounds like the switch has failed as it works all of the lights in and outside of the truck in conjunction with the bcm if you want to leave the battery connected and have the lights off pull the parking and headlight relays till you can replace the switch
If you want to disconnect the headlight switch
Do this on flat ground if you can
First put the truck in 1 and lower the steering wheel
Next remove the dash bezel
Next the switch I think it pops in place but check for screws first
If that don't work check to see if the sun load sensor on the dash isn't covered
