: remanufactored fuel injectors
02-18-13, 07:40 PM
2007 DTS with 76000K Are remanufactored injectors safe.
02-18-13, 08:16 PM
Oem fuel injector are very cheap. Acdelco part #2172443 you could get it either at rockauto.com or ebay. It better to get it new.
02-18-13, 08:46 PM
Why do you think you need a new injector ??
02-20-13, 02:12 PM
Send yours in to us and we clean, recondition, and flow match for $20 each.
02-20-13, 02:53 PM
^^^ Truth - Given decent care and cleaning there's nothing wrong with a "reman" injector. SC2150 would know ........
I will throw out a carrot: Google Chevron TECHRON and "top tier gasoline" - an ounce of prevention is better than a pound of cure.
02-20-13, 04:02 PM
Sub is correct....run a good top tier and the injectors will remain clean for the ife of the engine usually. Now to much additives can shorten the life of the injector internals so this is a case of "if a little is good, then alot must be REAL good", but only in moderation. I usually use Shell, BP, Mobile, Exxon for fuel choices. :thumbsup:
02-20-13, 07:45 PM
I use chevron with techron or fuel at the regular chevron but add the little chevron additive in or aloha gas station , 76 or shell
02-21-13, 06:34 PM
Engine lite has been on form months. Took to dealer who replaced plenum, but still on. Had all O2 sensors. There was a bulliten from GM saying replace them if under 100k.
