: D3 Competition Sedan ready to hit track this weekend!!
Dr. Design
02-18-13, 05:54 PM
We are putting the finishing touches of the D3 Competition Sedan and getting it ready for the 2013 Cadillac Challenge series. We look forward to seeing some of you at the Auto Club Speedway in Fontana, CA this Saturday.
Here is an image of the vehicle last time out at the track. We added some off-season goodies that should help the overall performance of the car.
http://cadillacrace.com/wp-content/uploads/2012/08/Cadillac-Challenge-Round-7-presented-by-Toyo-Tires-14.jpg
Thank you,
Dr. Design
D3 Cadillac
rand49er
02-18-13, 06:07 PM
Cool! Good luck in 2013!
mdleal
02-18-13, 06:09 PM
What size are those rear tires?
Dr. Design
02-18-13, 08:21 PM
335 R18's w/295's up front.
Thanks,
Dr. Design
D3 Cadillac
FuzzyLogic
02-18-13, 10:47 PM
What are you running in terms of transmission? Rebuilt T-56? Stock linkage?
repenttokyo
02-19-13, 02:53 PM
Good luck guys!
Dr. Design
02-19-13, 05:16 PM
It's a hybrid trans. We are using T-56 casing with T-6060 internals with various modifications and revisions.
We blew up the old T56... too much power.
Thanks,
Dr. Design
D3 Cadillac
FuzzyLogic
02-19-13, 05:34 PM
Thanks,
Dr. Design
D3 Cadillac
So you basically did the $2900 (http://www.summitracing.com/parts/cmg-tuet11009/overview/make/chevrolet) Magnum route (http://www.tremec.com/menu.php?m=104)? We've got a group of guys on the LS1Tech forums wanting to either rebuild our existing transmissions, or somehow adapt our linkage to the Magnum. Any fitment advice that you can provide would be greatly, greatly appreciated. Also...close ratio or wide ratio?
Dr. Design
02-20-13, 06:57 PM
Similar...certainly not exact. We went with a tight 1-4 and a tall 5-6 gear set. Not sure about the linkage as the techs were dealt the task of getting everything to mate up properly. Our combination isn't very stock anymore. We fabricated a custom ford 9" IRS with custom length driveshaft.
Thank you,
Dr. Design
D3 Cadillac
JDB
02-23-13, 08:22 PM
GL!
It would be be great to year the full specs of the car.
Dr. Design
02-26-13, 05:24 PM
Hello,
Here you go:
Build Sheet: Individual Tuning Components
/D3/ 427CID Competition Short Block
/D3/ Stage 3 Competition Cylinder Head w/Competition Valve Train
/D3/ Competition Camshaft
/D3/ Competition Aluminum Radiator
/D3/ Fuel Delivery System
MSD Coil Packs
MSD Plug Wires
/D3/ Quad Tipped Spark Plugs
Avaid 14qt Dry Sump Oil Delivery System
Setrab Dual Oil Coolers
AMSOIL fluids
Supercharger Upgrades
Harrop 2300 Supercharger
D3 Supercooler Intercooler System with 20Gal/Min Fluid Pump
Drivetrain
Custom T6060 level 5 Race Transmission
McLeod Racing Clutch
Driveshaft Shop Custom Driveshaft
Ford 9-inch IRS
Wavetrac Differential
/D3/ Steelflex Stainless Brake Lines
AP Racing Brake System
Exhaust System
/D3/ Long Tube Header + X Pipe
Custom Side Exit Exhaust
/D3/ Aerospace Thermal Ceramic Coating
Tuning/PCM
/D3/ PCM Mapping/Performance Tune
Chassis/Suspension/Electronics
D3 Competition Coil Over System
Hotchkis Sway Bars
Highly Modified Fender Extensions
/D3/ Carbon Fiber Front and Side Air Foils
APR GTC500 Spoiler
Racepak Data + Telemetry System
Sparco Racing Seats
Sparco 5pt Racing Harness
Competition Roll Cage
Wheels/Tires
Front: Forgeline Race 18 x 10.5 w/Toyo R888 295/30/18
Rear: Forgeline Race 18 x 12.0 w/Toyo R888 335/30/18
GL!
Thank you,
Dr. Design
D3 Cadillac
Naf
02-28-13, 02:27 AM
That's an impressive build sheet.
I have a 415Ci
Ported Ls9 heads
Fast 102 with 102Tb
GT1-1 Lingenfelter cam
NGK R spark plugs,
Custom Granatelli HTR wire set
Holley valve covers
102mm custom Maf
CF intake tube
Pumps out 625hp and 555lbft at the FW
Anze coilovers
Specter custom CF front fenders with 1" extentions
Specter CF doors
Specter CTS-Vr hood
Specter CF rear trunk
Brembo 8 piston front calipers with stock rear
Hawk performance brake pads for street and Raybestos for the track
14" two piece rotors front and rear
HRE C21 wheels running 275 front and 305 rear
Braille battery with new Silver coated electrical power lines
ARE dry sump system with a 11.5q tank
Sparco front racing seats with 6 point harness
Samco coolant hoses
Ron Davis Rad
Full custom grounding kit
RPM rebuilt tranny and rear diff in 3.42
Setrab Coolers for the PS, engine oil, the return line, and Transmission
ARE spintric air separator
Katech short shifter
GMPP sway bars
MAP trailing arms
Custom rear tie rods
GMPP upper rear arms
APR GTC-200 Adjustable Wing - SCCA Spec 48"
All in all a serious track car that can still get groceries every once and a while
Dr. Design
02-28-13, 01:56 PM
That's sounds like a nice build! Where are you located at? We would love to see images.
I have a 415Ci
Ported Ls9 heads
Fast 102 with 102Tb
NGK R spark plugs,
Holley valve covers
102mm custom Maf
CF intake tube
Anze coilovers
Specter CF doors
Specter CTS-Vr hood
Samco coolant hoses
Ron Davis Rad
GMPP sway bars
MAP trailing arms
Thanks,
Dr. Design
D3 Cadillac
