: Catera driveline axle / propeller shaft support bearing
retho78
02-17-13, 07:48 PM
Does anyone know what type, size of bearing it has in the driveline axle / propeller shaft support? The one in my in laws car started to squeak, rattle..etc.
I heard the noise after replacing the throttle body and test driving it, so did some investigation and found out that bearing is going bad.
Thanks.
retho78
02-18-13, 04:29 PM
How many bearings are there in the differential? Is it easy to replace it and any special tools required?
JohnJJO
02-18-13, 11:28 PM
u need to learn how to use search here on the forum....
http://www.cadillacforums.com/forums/cadillac-catera-cimarron-forum/270286-rear-pinion-bearing.html
retho78
02-23-13, 12:58 PM
Is it easy to unhook the drive shaft / propeller axle from the differential?
JohnJJO
02-23-13, 04:09 PM
use search !!!!!!!! its here on forum !!!! whole mechanic manual
http://files.spectralcoding.com/files/misc/catera/Driveshaft.pdf
