View Full Version : No start/crank, Like a bad ground...
Henry1940
02-16-13, 06:38 PM
I post this so maybe It will help someone from spending $599.00 for a dealer fix.
Turn key, display lights as normal, but no crank in start position..Turns out to be a bad ground UNDER THE FUSE BOX..in the engine
compartment..
Also when a dtc does comes up...don't fix anything until you have first cleaned that components connector plugs with an electrical contact spray cleaner...
Electrical problems abound..
Good luck
Henry1940
Vitaqueen
02-18-13, 05:20 AM
Thank you sweetie. Us DTSers need all the help we can get! Keep Rollin!
