: rear spead sensor
02-15-13, 07:09 PM
Can I change the right rear speed sensor with out getting a new hub.
On my 06 dts
big greg
02-16-13, 05:12 AM
Negative, they are built into the wheel hub, very easy to change though, and eBay has them for like 27$
02-16-13, 05:50 AM
A $27 hub/bearing assembly is good, if you enjoy replacing them often.
Stick with Ac Delco or Timken.
FWIW, the rear wheel speed sensors on Devilles/Sevilles are also integrated into the hubs, but are serviceable, and Rockauto does list the sensor separately. However, they also list the front sensor for Devilles/Sevilles, which is not serviceable.
big greg
02-16-13, 03:24 PM
I've been driving on mine for about 2 years now. I'm OK with that. Its not hard to do, timkens are nice but not for 5x the price
02-17-13, 03:42 PM
Thanks guy I cheack the abs/speed sensor wire and after I move them it is working find. I think the wire were ground it self on the rear control arm. I use a scanner that I got on ebay the code that I got was c0050. I got an actron cp9580 scanner for $70 it the best thing that I have done.
