: kooks with magnaflow question
vitsioto
02-13-13, 10:25 PM
Just curious do kooks catted extension pipes mount up with a magnaflow catback without any modifacation?
carlson_mn
02-13-13, 11:03 PM
From looking at the system on my car, yes. Installed by previous owner and he purchased the magnaflow off ebay, and everything bolts up under the car like it is OEM. My system has their high flow cats.
253ctsv
02-14-13, 02:20 AM
Call up Maryland speed and ask. They have a goid deal on kooks (I just bought kooks and corsa from them) they're pretty cool and I'm sure they'd know.
darkman
02-14-13, 06:41 AM
http://www.cadillacforums.com/forums/2004-2007-cadillac-cts-v-performance/188215-christmas-present-finally-some-kooks-headers.html
http://www.cadillacforums.com/forums/2004-2007-cadillac-cts-v-performance/187747-kooks-headers-magnaflow-exhaust.html
rand49er
02-14-13, 07:57 AM
JD03Cobra has Kooks and Magnaflow. Maybe he can add to the conversation or you can PM him.
JD03Cobra
02-14-13, 10:04 AM
I have the Kooks with kook extensions and the magnaflow cat back...No it did not mate up. It required some fab work...There are many threads stating it does not mate up nicely. Mine was at least 4" off. There was someone on the forum that reversed the X-Pipe and got it to work but it hung much lower. Kooks with catted extensions bolts right up to the Corsa exhaust, not Magnaflow.
You can see the fab work that was done to connect the two.
http://i106.photobucket.com/albums/m276/JD03Cobra/P3074932.jpg
http://i106.photobucket.com/albums/m276/JD03Cobra/P3074935.jpg
lilgCTS-V
02-14-13, 11:34 AM
i have kooks to magnaflow and to answer your question , you have to do some cutting and welding, i took my car to a muffler shop after the header install and had them put the catback on... 70 bucks cant beat it
vitsioto
02-14-13, 05:46 PM
Thanks for the responses. i thought the kooks catted conecting pipes for the stock cat back would match up with the magnaflow cat back.??
DMM
02-14-13, 07:53 PM
They work together just fine. Bolt the cats (or tuning pipes) to the headers and install the muffler axle-back portion. Overlay the X-pipe portion of the Magnaflow cat-back and trim a little at a time accordingly. You have to cut both ends of the Mgnaflow X-pipe section pipe, but everything will bolt up just fine. You can have it welded if you like, I welded mine b/c I didn't want to have the extra clamps in the system, but it's not required by any means.
I have the OE exhaust with the tuning pipes for tuning and the Magnaflow intermediate pipe welded together, so teh cats bolt to the headers and the mufflers clamp to the intermediate pipe. Easy peasy.
JD03Cobra
02-15-13, 09:59 AM
The OP's question was any modification necessary...of course they work just fine after fabrication work as you and I described.
DMM
02-15-13, 03:34 PM
I don't consider trimming a pipe with a reciprocating saw fabrication.
atdeneve
02-15-13, 03:48 PM
As far as the OP is concerned, it required modification and is not simply a bolt-in situation.
vitsioto
02-15-13, 05:35 PM
Thanks again for the replies one more question do u still have to hammer a dent in the header to clear steering shaft?
darkman
02-15-13, 08:15 PM
It depends. I believe that requirement is particular to the 1 7/8 size headers and does not apply to the 1 3/4 headers.
jclayc
02-15-13, 09:14 PM
Yes, some cutting with a recip saw is needed. Getting the cats turned just right so the o2 sensors don't touch the trans can be tricky. Get the wide clamps when you buy the headers and thatll give you some wiggle room. Even then, take it to an exhaust shop for them to weld instead of the clamps for long term happiness.
I had to dent mine w 1 3/4" kooks & the engine on revshift mounts
I bought my headers and high flows from maryland speed and had a good experience.
rand49er
02-15-13, 09:17 PM
... I had to dent mine w 1 3/4" kooks & the engine on revshift mounts ...No denting here with 1-3/4" Kooks. Worked like a charm.
JDB
02-17-13, 01:24 PM
sounds like fab work to me; not bolt in.
I don't understand why Kooks just doesn't make additional connector pipes to fit other exhausts.
Junior1
02-17-13, 05:55 PM
I've got 1 3/4" coated Kooks WITHOUT cats and a Magnaflow catback setup. NO dimple for the steering shaft and NO fab work. Bolted right up...
