: 5.7L 350 MAT sensor location???
02-12-13, 12:22 AM
Anyone know where the MAT (Manifold Air Temp) sensor is located on a 1990 Brougham 5.7L engine??
02-12-14, 11:08 PM
I know this is a year old so im sure you've found your answer, but I will answer it anyways incase someone searches and needs the info...
MAT sensor is located in the air cleaner housing, you will see a two wire connector protruding out of the bottom, lift the cleaner and you will see it.
