: Rid the rake? Lowering the rear.
CaddyEscalade
02-09-13, 02:35 AM
Is there a way to retain the factory air leveling system and lower the rear of the caddy to get rid of the rake? I would like to see the rear sit more level to the front.
Thanks in advance!
the cadillac man
02-09-13, 03:09 AM
Thanks in advance!
The rear sensors can be modified to lower the rear of the truck(make small adjustments till you get the desired results)
mikedyk43
02-09-13, 04:02 AM
Thanks in advance!
You will need lowering springs in the rear and also need to shorten the connecting rods on the rear sensors. I bought some long bolts that were the same diameter as the factory connecting rods and cut them to the length I needed. Keep in mind that lowering the rear more than about 3 inches and you have to start removing bump stops and perhaps cutting off the bumpstop mounts like I did.
CaddyEscalade
02-09-13, 10:19 PM
Is there any details on how to do this?
the cadillac man
02-09-13, 10:52 PM
Mike has lowered his escalade but if you go real low you will have to remove the bump stops and the mounts
As far as the sensor there should be a connecting rod on the sensor
CaddyEscalade
02-10-13, 01:29 AM
I don't want to lower it much, just to drop the rear an inch or 2. I don't want to go through the work changing springs. Thanks for the help.
mikedyk43
02-10-13, 01:36 AM
Let the air out of your rear shocks and if you want it lower than that, you will HAVE to change the springs...
90limited
02-10-13, 10:55 AM
Before I fixed the compressor, I had no rake, now the the shocks have air in them, I have the tail up in the air. I would guess that you could drop about an 3/4 to an inch by modifing the connecting rod. I would not allow the shocks to be completely empty, as IMHO it is not good for them.
the cadillac man
02-10-13, 12:21 PM
The rear shocks are a air/gas hybrid and I don't think it will hurt the shocks so much as it will the ride of the truck with the air out of the shocks
mikedyk43
02-10-13, 05:23 PM
I wasn't suggesting that he drive around with deflated airbags, just to see if the rear height was were he wanted without inflated shocks.
the cadillac man
02-10-13, 07:30 PM
I thought he was wanting the air out of them my mistake
mikedyk43
02-10-13, 08:11 PM
No worries, I was just pointing out that if he is not satisfied with the rear ride height with no air in the bags, he would have to install different springs.
