FlipperFish
12-31-04, 09:43 PM
In my 71 Eldorado the "generator" light on the dash stays illuminated after the car has been started. I have replaced the alternator with a new AC Delco piece, have a new battery, a new coil, changed all the fuses, and checked all connections religiously. However, the generator light nevers goes out after starting the car.
Haynes book mentions an external voltage regulator but I searched the car over and over and there is not one installed. Unfortunately, the book doesn't say exactly where it is installed on the car. I believe the new alternator has an internal regulator plus the wires indicate there is no external regulator in play, meaning the install of the alternator was plug-n-play.
I've pulled the negative battery cable while the car was running and the car continues to run with the negative cable disengaged.
The car seems to start fine and will run. The car is relatively new to me and I have only run it max 20 minutes.
Help!
Help!
