: 22 rims for 08 cts4
02-08-13, 05:01 AM
Brand: Lexani
Model: LSS-10
Color: 2 Tone Machined and Black Center, Chrome Outer
Size: 22" x 9"
Offset: Front - +30. Rear - +15
Bolt Pattern: 5 x 114.3
just wondering if these would fit and if they would what tires are recommended
02-08-13, 01:28 PM
We are 5x120 / 5x4.5 bolt pattern
And since you are an AWD , you will need same offset all way around I believe
Char T A
02-15-13, 08:18 PM
You don't need same offset with AWD but you need same diameter tires overall. The +15 rear is not going to work unless you want it to stick out of the fender on a sedan. I think for a 9" wheel you need +25 or higher. Also as mentioned bolt pattern is wrong.
No 22s yet but here are some 20" setups.
