View Full Version : "Secondary" Fuel Pump on 2010 SRX
LynnF
02-01-13, 03:47 PM
I took my SRX into the dealer today. It's been starting hard first start of the day (grinding over 30 seconds) and the "check engine light" came on on the weekend.
I had to replace the "secondary" fuel pump.
Just wondering if this is an anomaly or if others have had this problem.
I have 56500 km on it.
TheCaptain
02-01-13, 05:48 PM
65100 kms here with no issues at all with the fuel system.
redvett94
02-01-13, 09:29 PM
Do you run the tank low? Low fuel will burn out the pump in the tank. I would suspect the secondary fuel pump is the pump in the tank. I believe the primary pump is quite expensive as it produces over 1800 psi for Direct Injection.
300:29:1
02-01-13, 09:36 PM
Can someone confirm this business about running the fuel tank low? How low is low? This is 1 of those things that seems to be a subject of debate.
redvett94
02-01-13, 09:50 PM
The fuel pump is in the tank in fuel and its cooled and lubricated by gas. We had the same problem with Corvette ZR-1's and when the tank was low the dual pumps were junk.
Keep the tank above 1/4 tank or you will have the same problem again.
LynnF
02-02-13, 08:33 PM
There are 2 fuel pumps in the SRX: 1 in the fuel tank and one in the engine. I had to replace the one in the engine.[COLOR="Silver"]
redvett94
02-02-13, 09:11 PM
D.I. engines have 2 pumps the one on the engine is the high pressure pump it produces over 1500psi. I hope it was covered under warranty.
LynnF
02-02-13, 09:14 PM
Yes. Thank goodness. That's why I wanted to know if this was a common problem.
