View Full Version : Need Urgent Help With Brembo Calipers!!!....
2005_CTS-V
01-31-13, 10:50 PM
I just painted my calipers yesterday and now need to get them back together so I have a car to drive....does anyone know the torque spec's for reassembling the calipers? Hopefully someone can hit me back soon. Wrench in hand and ready. Thanks guys.
-Josh
FuzzyLogic
01-31-13, 10:57 PM
http://www.cadillacfaq.com/faq/answers/torque.html
darkman
02-01-13, 06:56 AM
The caiiper (bracket) bolts should be coated in threadlocker and allowed to dry (cure) about ten minutes. Torque is 96 ft. pounds. I have trouble getting the torque over 90 ft. pounds.
AAIIIC
02-01-13, 07:05 AM
The brake caliper overhaul section of the FSM tells you not to separate the caliper halves, so there's no torque spec listed. The bleeders are 124lb-in.
DrSpeed
02-01-13, 11:48 AM
Torque the caliper bolts PRIOR to loctite drying.
And read - bleeders are INCH POUNDS.
etcts-v
02-01-13, 02:01 PM
Did you separate the two halves of the calipers? If you did, I'm impressed you got them apart! I tried when I had mine powder coated and even with a 1/2 in socket with massive breaker bar, the heads on the nuts just wanted to strip before cracking loose.
darkman
02-01-13, 02:10 PM
See attached.
DrSpeed
02-01-13, 05:55 PM
See attached.
what?
Do you:
1. Apply loctite to bolts
2. Tighten them on the wheel end
3. Wait for the loctite to dry/cure
4. Then torque to spec?
You torque before the loctite sets, otherwise, you break the loctite free.
darkman
02-01-13, 06:59 PM
what?
Do you:
I follow the instructions in the GM Service Manual which says to (1) apply the threadlocker (GM 12345493) two-thirds of the threaded length of the caliper to knuckle mounting bolts with no gaps in the applied threadlocker; and (2) allow the treadlocker to cure approximately ten minutes before installation. GM's 12345493 threadlocker is Pematex Threadlocker Red and does not fully cure (or set) for 1-24 hours depending on temperature. Since it is an anaerobic material it cannot fully cure in the presence of air. The ten-minute curing time prescribed by GM is presumably required to ensure the threadlocker stays in the threads as opposed to be displaced by the rotation of the bolt (like a an Archimedes screw).
