: Anyone Pull a Travel Trailer?
oldrunner
01-31-13, 06:49 PM
Just purchased a 2006 Escalade with 97k miles, dealer serviced and so far can't find anything mechanical wrong with it. Anyone pull a travel trailer? If so, what length, weight, experiences, and advice? I've owned travel trailers in the past and I've read the towing capacity of the Escalade so I'm doing the research now and will be looking soon.
Thanks
wesyder
01-31-13, 09:44 PM
Thanks
Ur gonna need an electronic brake controller, i have the tekonsha prodigy p2, no travel trailers jus an enclosed car hauler, various uhaul trailers and a few boats
the cadillac man
01-31-13, 10:25 PM
I agree I towed a camper without the controller(I don't advise doing it without one) luckily it was a short distance but the escalade can tow up to three tons without a wight distributing hitch but with a camper it is best to use one along with stabilizer bars as it helps to handle the extra wight of the trailer
I am going to pick me up a brake controller before I get my flatbed trailer to haul my car on
FYI put the stabilizer bars on before you lower the trailer on to the ball fully(best is when the tongue starts to lower the rear) as it will cause extra strain on the rear shocks and compressor
I say this because three months after I towed the camper my rear drivers side shock blew due to improper procedure
wesyder
01-31-13, 10:28 PM
Cadi man look into that as most flatbeds have hydro brakes
the cadillac man
01-31-13, 11:12 PM
Ok I will before I get one but it will be a while as I am still working on the car and thanks for the heads up on the difference on the brakes
T-Bones
02-01-13, 08:46 AM
I pull a 1981 31' airstream with my 04 escalade. My trailer weighs just less than 5000 lbs. With family and more gear than anyone should have to take camping (or so it seems)I'm sure I'm up over 6500lbs. The 6.0l is awesome never shy on power. Defiantly need a brake controller. The other thing I have noticed is that the transmission runs cooler in 3rd than in tow/haul mode. The shift patter also suits my driving style. I try not to be in a rush when on a trip.
wesyder
02-01-13, 08:48 AM
Nice rig
jnrsesv
02-01-13, 09:00 AM
Def nice rig. Towing should NOT be done with the overdrive engaged.
Factory Towing Wire Harness
Just a heads up fellows. Our Platinum came with a plug and play "Brake Controller Pigtail" GM Part #15085418. Might be worth looking into rather than hacking wires.
Instructions on tag:
"Glove Box Jumper - Electrical Installation Instructions
1) The brake controller pigtail and 40A B+ Trailering J-Case fuse has been provided with the HD trailering option"
http://i782.photobucket.com/albums/yy103/jnrkara/2005%20Escalade%20ESV/Brake%20Controller%20Pigtail/GMPart15085418_zps5262ca52.jpg
http://i782.photobucket.com/albums/yy103/jnrkara/2005%20Escalade%20ESV/Brake%20Controller%20Pigtail/DSCN6713_zpsf38becae.jpg
http://i782.photobucket.com/albums/yy103/jnrkara/2005%20Escalade%20ESV/Brake%20Controller%20Pigtail/DSCN6706_zps8f8aca59.jpg
http://i782.photobucket.com/albums/yy103/jnrkara/2005%20Escalade%20ESV/Brake%20Controller%20Pigtail/DSCN6705_zps3cf6d0ce.jpg
jd_mpmt
02-01-13, 10:11 AM
I have a 05 ESV with about 125k on it and pull a 36 foot travel trailer...I forgot the weight but she a heavy one with two slides and hitch weight of about 1100 lbs....I have had no problems pulling. I did however find a leak in the rear air shocks after my road trip to the Blue Ridge Mountians. BTW fuel avg for the trip to TN from MI was about 8-9 MPG....using 93 oct and tow haul mode...I replaced the shocks with the ARNOTT replacements and a new air compressor from them while I was at it. The dealer will try and hit you up for $1600 just for the rear air shocks, I did the rear air shocks, compressor and install for about $900 with a buddy of mine.
My Suggestions... Check your air system for crack or leaks....replace ALL the fluids!! diff, transfer case, transmission... there is a great thread here for it I think by "Cadillac Man"...very easy DIY....I used all AMSOIL in mine and did it all in my driveway, minus the transmission because dealer had done it for me when I bought it.
the cadillac man
02-01-13, 11:17 AM
With that size of trailer it's better to downshift but are you using the right hitch?
The tow /haul mode delays the shift pattern to keep the tranny cooler but in some cases it's better to downshift when needed as it also delays kickdowns
All gm trucks and SUVs are plug and play with the brake controller also nice rig
T-Bones
02-01-13, 11:40 AM
Thanks for the warm reception. We really like it. Both the escalade and the vintage airstream that is. Double that about changing all your fluids. I also use amsol.
The plug and play is the way to go for wiring in the brake controller. Super simple.
As far as down shifting I haven't pulled it an any mountain roads yet but have no fears when I do. The tow haul mode seems to aggressive for my liking. I am pretty cautious not to beat my old rig. I have a lot of time invested into it. Some money too but a lot more time. The shift pattern in the tow mode may work for some people but I like just straight 3rd.
Hitch. I am using the proper hitch it just dosent look like it in the picture. I have levelled everything out since then.
Thanks again
oldrunner
02-01-13, 11:49 AM
Good info, thanks for all your input. Love that Airstream, bet you turn heads when you arrive at the park. :)
Really interested in the plug and play brake control, must look into it further. I assume that since I don't have 4wd I don't have a front differential? How easy is it to change the fluid in the transmission?
Thanks Again
the cadillac man
02-01-13, 12:40 PM
Thanks again
That's what my uncle does its better for a bigger trailer even though the tranny is designed to use the tow haul mode in order to"save wear" but it does put more load on the engine using the proper hitch is the main thing when towing a trailer this big(and is a wise decision)
I am the same way with my I baby it as much as I can
wesyder
02-01-13, 12:40 PM
Thanks Again
I may have an extra plug and play harness for the controller if anyone is interested
the cadillac man
02-01-13, 12:48 PM
I don't have the control box so the harness wouldn't help
T-Bones
02-01-13, 08:39 PM
There is a stickie on changing the tranny fluid as well as the diff and t- case. It's pretty easy. Just did mine last week.
oldrunner
02-01-13, 10:37 PM
The sticky is just replacing the fluid. I would think the better plan at 100k would be to drop the pan and replace the filter though I'm no expert. My mechanic will do it for $222.
the cadillac man
02-01-13, 10:51 PM
I agree
Black88GTA
02-02-13, 01:51 AM
I may be interested actually, as I'm going to have to haul a trailer with a car on it at some point this year. How do you tell if you have the controller installed? Is there an RPO code for it? Mine has the hitch receiver, but I don't know if it's got the controller or not.
the cadillac man
02-02-13, 03:20 AM
If the truck has the trailer package(with the hitch()then it is prewired
T-Bones
02-02-13, 09:36 AM
I believe on that sticky there is someone who posted pictures of dropping the pan and checking/ changing the filter.
