: New to me 2011 SRX, forum newbie
kathykip
01-22-13, 12:19 PM
Hi All,
I just got my 2011 SRX Luxury last week on Wed. I'd been looking at them for quite sometime. I went from a very basic 2008 Ford Escape Hybrid to this car and I'm almost overwhelmed at the bells and whistles. But it's in the shop :-( The driver's side headlight was weak and at night I felt like I couldn't see anything to the left. I took in in yesterday for them to program a new fob, check the headlight and give it a good detail. Last night the service dept called and said they'd had to order a new headlamp assembly and it'd be in today. Dumb question, but aren't the bulbs replaceable? would this model have the AFL lights I've read about in the manual?
Thanks!! I'm enjoying reading through the forum, you all are so helpful!!!
GMJim
01-22-13, 12:45 PM
Welcome, Congrats, and thanks for choosing GM.
That is quite the jump from an Escape! Bulbs are replaceable, so
it must have been a larger issue. Base & Luxury do not have AFL.
phunter1
01-22-13, 01:01 PM
Not sure why they would order a headlight if it wasn't damaged. The bulbs are most certainly replaceable. I replaced mine with Phillips Crystal Vision Ultra bulbs because I wasn't happy with the brightness of the stock halogen bulb. Bulb replacement is located in Chapter 10 of the owners manual. The Luxury model has halogen projectors on the low beams but does not have the Adaptive Forward Lighting headlights you mentioned. The AFL's are on the Performance and Premium models only. One way to tell which headlight you have is the daytime running lights. On the halogen lights, the low beam and high beam lights are separate and the low beam is also the daytime running lights. The high beam is the lower inside light. On the AFL's, the daytime running light is the lower inside bulb and the low beam light is also the high beams, and they are not used as daytime running lights.
Since you just got it, are you sure it is a Luxury model and not a higher model?
Phil
2011SRXMo
01-22-13, 01:14 PM
welcome to the SRX family
Cadillac Cust Svc
01-22-13, 02:44 PM
Welcome to the forum, kathykip! If you would ever like me to call your dealership on your behalf to follow up on questions for you, then please let me know. I'm happy to contact your dealer and research concerns for you, so please email me at Katie_Lucille@gmexpert.com anytime for further assistance.
Best,
Katie
Cadillac Customer Service
TheCaptain
01-22-13, 09:37 PM
Welcome Kathy!
kathykip
01-23-13, 10:58 AM
Thanks All! Turns out the Headlamp assembly was "fogged" (read that damaged) inside, looked clear to me. But the new assembly did the trick and I have light on both sides.
Phil, the paperwork says it's the Luxury. Is there a way to find out from the VIN which is really is? Not that they are providing incorrect information, just for my own curiosity...
Marc NY
01-23-13, 12:27 PM
... Is there a way to find out from the VIN which is really is? Not that they are providing incorrect information, just for my own curiosity...Your VIN# will tell your build history and what options you have on your SRX.
If you want to give me your last 8 of your VIN# I can email you a copy or post it for you to see here.
phunter1
01-23-13, 12:29 PM
Probably, but I don't know where you can get it. Perhaps someone else knows? Easy way to tell is if it has a rear power lift gate, wood trim inside, sun roof and no AFL, it is a Luxury. The Basic model does not have wood trim, power tail gate, nor a sunroof. Higher Performance and Premium models have AFL and 20" wheels among other things. 20" wheels not a good way to tell though, because they can be ordered as an option.
Hope your headlight assembly was replaced under warranty, as they can be expensive.
Phil
kathykip
01-23-13, 01:13 PM
Thanks Marc! The VIN is BS632402. Posted here or email, either is fine :-)
Phil, From from you posted it is a Luxury model. The headlamp assembly was covered by the warranty.
Thanks again!!
Marc NY
01-23-13, 04:03 PM
Thanks again!!Great... my GM web-link is down at the moment. Hopefully it will come back on line before I go home... when it does I will post your build history for you.
Marc NY
01-25-13, 02:43 PM
I must appologize for the website address was changed and it took me a couple of days to figure out what the problem was. :(
Here is your Build Sheet:
Vehicle Information
VIN: 3G******BS632402 Model: 6NG26-2011 SRX V6
Service Contract: No Branded Title: No Warranty Block: No PDI Status: Yes
Order Type: 50 - FLEET
Field Actions: 0 Open
Vehicle Build
Model: 6NG26-2011 SRX V6 Order Number: PJMJQZ
Gross Vehicle Weight: 2,482 Build Date: 03/28/2011
Option Codes
*IVH is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
01E - INTERIOR TRIM 1AF - DOOR TRIM
1SB - LUXURY COLLECTION 1SZ - OPTION DISCOUNT
2BX - SAPELE WOOD TRIM PACKAGE 44F - WOOD TRIM PACKAGE
4AJ - INTERIOR TRIM 5AD - SAPELE SHIFT KNOB
6AA - SUSPENSION 7AA - SUSPENSION
8X2 - SUSPENSION 9X2 - SUSPENSION
AAB - DRIVER MEMORY PACKAGE AFD - TITANIUM WITH EBONY
AG2 - POWER SEAT ADJUSTER AL0 - AUTO OCCUPANT SENSING
AL2 - POWER LUMBAR ANY - REAR CARGO STORAGE
AR9 - FRONT BUCKET SEATS ASV - HUMIDITY SENSOR
ATH - PASSIVE ENTRY SYSTEM AXP - MPV
AY0 - AIRBAGS BTV - REMOTE VEHICLE START
BZ4 - PROD WEEK C1U - FLT-ENTERPRISE RENT A CAR
C3U - SUNROOF, POWER ULTRAVIEW C9X - GVW RATING, 2,480 KG
CEC - WIPERS, RAINSENSE CJ2 - DUAL ZONE HVAC
D42 - REAR CARGO SHADE DCP - ONSTAR, DIRECTION AND CONNECT
DD8 - MIRROR, ISRV DR4 - MIRRORS, OSRV POWER, HEATED
EBS - SEAT TRIM EF7 - USA
F07 - REAR AXLE, 3.39 RATIO FBJ - INTERIOR TRIM
FE2 - SUSPENSION, 4-WHEEL FLT - FLEET PROCESSING OPTION
GBA - BLACK RAVEN JF4 - POWER ADJUSTABLE PEDALS
JJK - SUSPENSION JL9 - BRAKES 4-WHEEL ANTILOCK
KA1 - HEATED SEATS KG4 - 150 AMP GENERATOR
LF1 - 3.0L VVT DOHC V6 SIDI ENGINE LHD - LEFT HAND DRIVE
MH2 - TRANSMISSION, 6-SPEED AUTOMATIC NP5 - LEATHER WRAP STEERING WHEEL
NU5 - EMISSIONS, CALIFORNIA QF8 - 18" POLISHED ALUMINUM WHEELS
QMY - 18" ALS BW TIRES R6F - B-CODE ASSIGNMENT
R9N - PROCESSING CODE - INTERIOR TRIM R9Z - POMS EXPEDITE-SOLD ORDERS/TSE
SAL - RAMOS ARIZPE T61 - DAYTIME RUNNING LAMPS
TB5 - POWER LIFT GATE TSQ - INTERIOR LAMP PACKAGE
U2K - XM RADIO - SERVICE SUBSCRIPTION SOLD SEPARATELY BY SIRIUS/XM AFTER 3 MONTHS U30 - CLUSTER
U70 - DRIVER INFO CENTER DISPLAY UA6 - THEFT DETERRENT
UD5 - PARKING ASSIST, FRONT/REAR UE1 - 1 YR ONSTAR DIRECTIONS WITH AUTOMATIC CRASH RESPONSE & TURN-BY-TURN NAVIGATION (ASK DLR ABOUT GEOGRAPHIC COVERAGE)
UEC - SENSOR AUTO AIR RECIRC. UG1 - UNIVERSAL HOME REMOTE
UPF - BLUETOOTH FOR PHONE UQA - BOSE PREMIUM SPEAKERS
UVC - REAR VIEW CAMERA UYE - AM/FM/XM STEREO, SINGLE DISC
V64 - ROOF RAILS, SILVER V8D - US VEHICLE STATEMENT
VH9 - OWNER INFO ENVELOPE VK3 - FRONT LICENSE PLATE BRACKET
VQ2 - FLEET ORDERING AND ASSISTANCE VT7 - OWNERS MANUAL
VVO - SAPELE CONSOLE VX7 - FLT-PURCHASE RISK PROGRAM
YF5 - 50-STATE EMISSIONS ZAA - COMPACT SPARE TIRE
kathykip
01-28-13, 12:16 PM
Thanks MarcNY! :-)
GMJim
01-28-13, 01:35 PM
it took me a couple days to find it also.....
r1concepts
01-28-13, 03:54 PM
Welcome to the site! You'll find everything you need to know right on here.
