: stock wheel offsets...help!
01-21-13, 03:03 PM
Does anyone know the stock wheel offsets for a 2011 coupe 3.6 AWD??
Char T A
01-21-13, 08:47 PM
Check www.customoffsets.com I am almost positive we have these listed in our gallery. Look for the red "Stock Offsets" stamp on the photos.
01-22-13, 04:49 PM
+48 front---+32 rear
01-22-13, 07:19 PM
Ive searched around but couldnt find any pictures of a sedan with V coup wheels
I coulda sworn someone wrote about it
ANy help?
01-22-13, 09:15 PM
thanks guys...anyone know if getting +35 offset all around on 18x8 fronts and 18x9.5 rear (while keeping stock tires) will be an issue? I was told these sizes were made for my car
C "T" ess
01-27-13, 12:57 PM
7 mm of off-set difference isn't too bad as far as outer bearing load, but I would definitely stay under 10 mm.
01-27-13, 02:50 PM
As you saw in my other post, I went with that setup. The fronts are a +13 difference from stock but also 1/2 inch less in terms of depth (18x8 instead of 8.5). Anything I should be concerned about?
