: intercooler pump upgrade
Carlosg
01-20-13, 09:55 PM
Where can I get one and what are using. Give me a link.
PGA2B
01-20-13, 10:18 PM
Jabsco 50840-0012
http://www.imarineusa.com/jabscolowpressurecycloncentrifugalpump12v.aspx?gcl id=CKHe6I6x-LQCFSmCQgod5lUAQA
Carlosg
01-20-13, 11:15 PM
What else would I need fitting?
PGA2B
01-21-13, 10:52 AM
You will need 2 NPT to hose fittings that you can get at Home Depot or Lowe's. You will also need to fabricate a bracket to hold as it is not a direct swap. I used the factory bracket and made another one to attach to the factory bracket. Not extremely difficult, but take a little time.
Carlosg
01-21-13, 09:43 PM
Thank for your help, how do you do the wire, positive n negative only.
PGA2B
01-21-13, 11:06 PM
Yes there are only 2 wires.
Carlosg
01-30-13, 11:22 PM
I understand you have cut the bracket but how about the pump did you bend the bracket so it could face up in the to hose alignment.
PGA2B
01-31-13, 12:12 AM
You have to change the orientation of the outlet. There are a couple of screws in the top of the motor (NOT THE 3 ON TOP OF THE UNIT) you take out and move the outlet.
Carlosg
01-31-13, 07:50 PM
Thank for the help.
