View Full Version : signal lights do not flash - 76 CDV
mjburger
12-29-04, 03:49 AM
I would sure appreciate any help on this. Replaced the flasher but they do not blink, Fuses are all good in the fuse box and all the bulbs are working..
Any suggestions?
Thanks
Martin
davesdeville
12-29-04, 04:58 AM
I really don't know, but have you checked the hazard lights? Maybe that could narrow it down.
mjburger
12-29-04, 01:17 PM
Hazards do not flash either...
Thanks
Martin
Scottie in Alabama
12-29-04, 05:01 PM
If they come on and burn steady, most likely it's a bulb somewhere. However, check all bulbs and sockets for corrosion. This could cause one not to burn or connect properly.
mjburger
12-29-04, 09:53 PM
My mistake the hazards do indeed flash....the first time I checked the Hazards I had the brake on and they do not flash with the brake on.
They do flash if that helps to diagnos this problem.
All bulbs are lit
Thanks
Martin
