View Full Version : Need specific advice
sandalet
01-13-13, 05:58 PM
Hey, guys. I'm going to turn in 2003 3.2 CTS-V. To do this, I'll buy some broken CTS-V and change it to the engine, gearbox and other parts of the CTS-V. I can not buy ready-V, because in my country is very high import duties on a large number of engines. My question is, what are the common parts of my V and 3.2? Suspension, manual transmission, drive shafts the same? Can I leave the wiring in the cockpit, or need to be replaced? ...
AAIIIC
01-13-13, 10:00 PM
The suspension and chassis are the same (different dampers, springs, and anti-roll bars, but the control arms, crossmembers, mounting locations, etc are all the same).
I would guess the interior wiring is largely the same. The V came with some added features that the V6s didn't have, but I don't know how much of that is needed to run the V's engine.
Transmission is different - the V uses a Tremec T56 6-speed. Even the V6s that have a 6-speed don't use the Tremec.
sandalet
01-14-13, 01:43 AM
Delete
odthetruth
01-14-13, 02:39 AM
I'll close. Contact me if anything.
odthetruth
01-14-13, 09:38 PM
Reopened
HAMSTAR
01-14-13, 09:51 PM
No offense to this board, but this seems like the type of very technical information that is more readily available on LS1tech. OP, I suggest you post your question there: http://ls1tech.com/forums/cadillac-cts-v-68/
odthetruth
01-14-13, 10:53 PM
Seems same people post in both forums.
Either way... this would be a big job, you'd need the entire engine cradle, engine, all harnesses, ECM, driveshaft, diff, axles, etc etc etc from a V. A majority of the suspension is about the same, but about the same =/= the same. You'd have a better chance, financially, of buying a V and importing it, vs the headache that would be a total conversion.
sandalet
03-19-13, 05:23 PM
I hired an inspector and made auction deposit. I see lots of interest to me, I ask for your advice, which ones are meaningful to buy? The average price in my experience 2800-4500 dollars. I am willing to spend a maximum of $ 4,800.
1. https://www.iaai.com/Vehicles/VehicleDetails.aspx?auctionID=&itemID=14184431&RowNumber=0
2. https://www.iaai.com/Vehicles/VehicleDetails.aspx?auctionID=&itemID=14209906&RowNumber=1
3. https://www.iaai.com/Vehicles/VehicleDetails.aspx?auctionID=&itemID=14215747&RowNumber=2
4. https://www.iaai.com/Vehicles/VehicleDetails.aspx?auctionID=&itemID=14015114&RowNumber=3
5. https://www.iaai.com/Vehicles/VehicleDetails.aspx?auctionID=&itemID=14181150&RowNumber=4
6. https://www.iaai.com/Vehicles/VehicleDetails.aspx?auctionID=&itemID=14165408&RowNumber=5
7. https://www.iaai.com/Vehicles/VehicleDetails.aspx?auctionID=&itemID=14040764&RowNumber=6
8. https://www.iaai.com/Vehicles/VehicleDetails.aspx?auctionID=&itemID=14277911&RowNumber=7
9. https://www.iaai.com/Vehicles/VehicleDetails.aspx?auctionID=&itemID=14329519&RowNumber=8
