View Full Version : What's the best way to replace a water pump on a 76 deville
Colto45o
01-12-13, 09:59 PM
What all is needed to replace the water pump on a 76 deville and easiest way on the 500
deVille33
01-13-13, 11:14 AM
There are no shortcuts. First U need to remove the radiator fan shroud from the radiator support and hang it on the fan. Then the radiator, so it does not get damaged. You can then crack the bolts holding the fan to the pump stem. If you have the clutched fan, you can remove this first. Loosen the assesories so the belts will come free. Remove the extention from the pump stem. Last remove the pump from the front cover. Good idea to drop the coolant and flush the system with a neutralizer before you start all this. I covered all this on another post here recently. Search my posts and you will find the explanation there. When you replace the pump it is a good time to replace all the hoses.
Colto45o
01-13-13, 12:12 PM
Thanks I appreciate that
jayoldschool
01-18-13, 01:39 PM
If you look in the RWD section, I posted pics of the water pump replacement on a 368 (same procedure as 500) in my coupe project thread.
