: What coil overs do I have?
tshort
01-11-13, 07:00 PM
My front driver shock was leaking oil so I cross referenced the shock numbers and ordered a new shock. Well, after pulling the shock (actually it's a coil-over) it appears I've probably something custom. I'll try and post a picture of it below but if it doesn't come out, it is a Sachs shock 6MH 25772234 with Ebach springs and a coil over threaded perch attached. There doesn't appear to be any way to remove the threaded perch from the shock to use with the new one.
Anybody know what I have and how to get a replacement?
Thanks!
darkman
01-11-13, 07:20 PM
The threaded perch looks like a Ground Control setup. The shock number does not match what I show for an FE4, but does match a listing for a CTS shock.
http://www.cadillacfaq.com/faq/index.html
tshort
01-11-13, 07:26 PM
The top 'cap' on the shock, above the threaded perch, will that pop off or is that pressed on holding the internals in?
darkman
01-11-13, 07:37 PM
If you go to the link in previous post and click on Suspension/Steering - there is a list of artcles including on installing the Ground Control system with pictures. There are also articles with shock-related part numbers.
tshort
01-11-13, 08:03 PM
I'll do that. Thanks a bunch!
tshort
01-11-13, 10:56 PM
Cool...the top 'hat' just pops off and I was able to adapt the threaded perch to the new shock. Back in business!
