View Full Version : left side mirror wont work
Robert8b
01-10-13, 09:44 PM
My left side mirror wont work when im trying to adjust it. Could it just be a fuse? help!! thanks
ddalder
01-10-13, 09:54 PM
This will not be a fuse. The mirror is powered by the Driver Door Module. If the fuse was blown for this module, none of your door functions would work. The problem could be a few things from a bad door module to a bad switch or mirror adjuster. So the right side works fine, but when you switch to the left it doesn't? There is a center position. Is it possible that you may not be moving the switch all the way to the left?
