View Full Version : caddy won't start, cold weather in Buffalo
caddybrougham87
12-26-04, 11:09 PM
have a 87 caddy brougham with a 307 engine. replaced battery with a silver diehard, put dry gas into the tank. engine is turning over but not seeming to getting gas to start. when we remove air cleaner and open 4 barrel flap it seem to help at first, but it still not starting. over the last few days it has been impossible to get started, before that, it was a hard start but if i could warm up the engine it ran great. does anyone have any ideas for me. its been preety cold here in buffalo, but i never had this problem before. i wonder about maybe a froze gas line but i thought the dry gas would help. also does anybody think my 4 barrel needs rebuilding. any help is appreciated.
Barry Clark
12-27-04, 05:46 PM
I only add this as you didn't mention it: do you have a block heater? Maybe the it is too cold around the engine block for the fuel to vaporize. Just a thought.
caddybrougham87
12-27-04, 06:45 PM
no it doesnt have a engine block heater. im thinking that the fuel lines are frozen and cant get fuel to the engine. i dont have a warm garage to put in either. the car is parked in driveway. it has been pretty cold here in buffalo. i heard its not suppose to get above freezing until friday, but i cant wait that long !!! oh well i guess i need to drive my caddy everyday from now on. any other suggestions for my problem please post.
RBraczyk
12-27-04, 07:04 PM
I just skimmed but Choke cable?
DaveSmed
12-28-04, 02:09 AM
Nope Automatic choke. When you pump the accelerator, does fuel squirt into the primaries? And on the choke.... Does it close fully?
brougham
12-28-04, 05:05 PM
There's probably something wrong with your choke or the carberator. Did you try using Quick Start?
CadiJeff
12-28-04, 07:29 PM
as an experiment squirt some starting fluid into it and see if it fires
caddybrougham87
12-30-04, 12:19 PM
well it got up to 40 degrees and i tried starting the car again, but it still wouldnt start. so i called up my mechanic and hes looking at it right now. ill let everyone know what is wrong with it when i get the details.
caddybrougham87
01-13-05, 01:32 PM
well i finally got my caddy back. this is what my mechanic did and it is running excellent :)
replaced distributor cap and rotor and removed spark plugs and cleaned them because they were wet from the engine being flooded from when i tried starting it.
he also replaced the choke unit and choke unit pull off and fixed vacuum leaks. the thing was a mess. but now i can really feel a performance boost from the new spark plugs and wires. even though the 307 isnt really that powerful for a 4000lb car.
SedanDeWiLL95
01-25-05, 11:31 AM
sweet deal good thing it's fixed
i'm in niagara falls.. my deville says Bring it! haha
riddle_18
02-22-05, 04:52 PM
92 fleetwood, I'm from Gowanda, 4.9 8Cyl.. it's saying bring it too... lol
