: TPMS part#
sapien
01-03-13, 10:56 PM
Can anyone confirm the OEM part number for the TPMS valve, is it 25758220? (I presume all STS's use the same one, 315 MHz?)
Anyone have experience with compatible aftermarket TPMS's?
dkozloski
01-03-13, 11:12 PM
NAPA is good.
Loren
01-04-13, 10:00 AM
http://gm-partscenter.com/parts/index.cfm?make=Cadillac&year=2005&model=STS&submodel=&searchText=13586335&action=oePartSearch&siteid=215875
http://www.ebay.com/itm/GM-TPMS-Tire-Pressure-Monitoring-System-Sensors-by-GM-13586335-See-Compatibility-/150850934619?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A2005%7CMake%3ACadillac&hash=item231f6a975b&vxp=mtr#ht_547wt_663
neverlateSTS
01-04-13, 11:21 AM
the 25758220 is the AC Delco part number for the TPMS I replaced mine this past month using part number 974-012 from Dorman aftermarket and they worked fine.Great customer support also as the tire place tried to set them and with their snap on tool could not get them to read. You must install then wait 30 minutes with car at rest then take for a short drive. i then used the old deflate method and it worked perfect. I aired the tires up to around 45-50 psi did the relearn and set them back to normal. Good luck
Mullah88
01-04-13, 02:34 PM
if your changing one, change all of them! i changed my LF in early december and now the RF is acting up...ill take it back in and change the remaining 3 sensors
chazglenn3
01-05-13, 06:21 PM
My local Discount Tire sells them installed for $60.
mckellyb
01-16-13, 09:49 AM
Chazglenn3, $60 each?
chazglenn3
01-16-13, 01:25 PM
Yes, $60 each. I've never bought more than one at a time so I don't know if the install cost changes for multiples.
Charles
