: Fog light
1SGLAC
01-02-13, 01:01 PM
My fog lights are not working. Saw a burnt fuse ? I replaced it and burned again. What could it be?
curtc
01-02-13, 01:13 PM
Got a short in your fog light wiring somewhere I'd guess, time to get some schematics.
1BadCadSTS
01-02-13, 01:37 PM
Fog lamp relay.
B1n2fra
01-02-13, 02:18 PM
Are bulbs 55watts because anything more could melt wiring and cause positive and negative terminals to touch.
1BadCadSTS
01-02-13, 06:45 PM
Aftermarket hids using factory wiring 35watt at best. Anything more get a relay harness.
Ludacrisvp
01-02-13, 07:33 PM
Stock fogs are H3 55watt.
1SGLAC
01-02-13, 07:41 PM
Where is the relay fuse for the fog lights. In side the car or next to engine?
ddalder
01-02-13, 10:37 PM
The fog lights are fused, the relays are not. If you've found the fuse and it blows when you replace it, you need to start looking for a short somewhere in the circuit. You could start by checking the connections at the lamp first, then trace wiring back from there. Don't ever use a fuse larger that what GM specifies, but make sure that the fuse in the circuit is the correct rating.
