View Full Version : Replacing Rotors and Pads... opinions??
mwhayes
12-27-12, 10:11 AM
what brand of pads and rotors do you prefer and why.
thanks
jclayc
12-27-12, 11:44 AM
street or track?
darkman
12-27-12, 11:59 AM
A good starting point for the street is the stock rotors with stock pads - this is an excellent setup in terms of stopping power, noise, and longevity. They can be purchased from Lindsay Cadillac at a discount.
thebigjimsho
12-27-12, 01:04 PM
I like stock rotors with Hawk HP+ pads...
crankedupforit
12-27-12, 04:26 PM
Da troof!
r1concepts
12-27-12, 05:20 PM
Hey if your looking for new rotors and pads, feel free to PM me and I'd be glad to help you out!
RyRidesMotoX
12-27-12, 06:48 PM
I ran R1 stuff on my cobalt. I was pleased with it.
mwhayes
12-27-12, 11:53 PM
street setup, I like the stock rotors but whatever pads are on there now generate so much dust
Andringa
01-03-13, 12:09 PM
You probably have stock pads on now. If you want less dust and don't mind giving up a bit of performance I've heard good things about Hawk HPS.
If you don't like dust you definitely do not want to go with HP+
repenttokyo
01-04-13, 04:15 PM
exactly what I am running on the track as well. They are noisier than they were on my Miata when I drive it on the street, however.
JDB
01-04-13, 05:07 PM
You run Hawk HP+ on the track in your V?? With such a heavy beast, I would probably cook those...or maybe I should brake less, since they only slow you down. Hawk HP+ will be fine ins Mistakes on track, but if you use the brakes and at a big track that uses a lot of brakes...I highly recommend going further up the heat range of pads for the track...at least Hawk HT10/14 or more like DTC70 fronts and DTC60 rears.
PISNUOFF
01-05-13, 09:40 AM
I busted two R1 Concepts rotors on the street. They were cross drilled front rotors. I still run the R1's on the rear at the track with Carbotech pads.
http://i1125.photobucket.com/albums/l586/bruckde/0b6c8513.jpg
repenttokyo
01-06-13, 12:40 PM
I haven't had any problems with the pads so far. No cooking, multiple sessions.
RyRidesMotoX
01-08-13, 03:41 PM
That sucks. Did they replace/warranty it?
PISNUOFF
01-08-13, 05:16 PM
Yes, they replaced with no questions asked. Their customer service was excellent. I attribute the cross drilled ones breaking to my aggressive driving style with many hard stops from triple digits. I don't think there is a steel rotor that is cross drilled that will withstand my driving. That's why I never asked to have the second one replaced, not because of any particular brand of drilled rotors.
As a reference:
1. My brother has had a C5 Z06 with over 650 rwHp and stock brakes for 7 years. He drives very aggressively. We swapped vehicles for 6 weeks and I cracked one of his stock fronts (cross drilled) with stock pads in three weeks.
2. I have slotted fronts on my V that have 1/2" cracks on the solid surfaces.
RyRidesMotoX
01-08-13, 07:22 PM
Sweet baby Jesus... I haven't had cross drilled rotors on anything cuz I'm always weary of cracking but I don't drive that hard.
thebigjimsho
01-09-13, 05:21 PM
You run Hawk HP+ on the track in your V?? With such a heavy beast, I would probably cook those...or maybe I should brake less, since they only slow you down. Hawk HP+ will be fine ins Mistakes on track, but if you use the brakes and at a big track that uses a lot of brakes...I highly recommend going further up the heat range of pads for the track...at least Hawk HT10/14 or more like DTC70 fronts and DTC60 rears.If you're on street tires, HP+ is all you need. If you're upping tires, up your pads...
Isaacs
01-10-13, 09:45 PM
I'm running Centric blanks, HP+ pads and ATE superblue with no problems. Been through a couple trackday sessions and hard mtn driving with great results. Ordered it thru- http://knsbrakes.com/index.php Decent prices, fast shipping and good customer service.
JDB
01-10-13, 09:53 PM
Maybe for a beginner - intermediate driver. No way, as an Advanced ...or, like I said, I need to learn to brake less. Even in a lighter car, I cooked Hawk HT10 up front (with Hawk Blues on the rear).
FWIW, in my V, I use PFC01 pads up front with Hawk HP+ rears on the track and its been great.
2007V
01-11-13, 01:07 AM
I went OEM rotors and hps pads. OEM pads are much better. The HPS have less dust but I miss the performance.
tshort
01-14-13, 10:25 AM
Where is the best place to get OEM rotors and pads? I need to do my brakes also. Can you get them locally or do you need to order them?
darkman
01-14-13, 11:59 AM
If you can find a local dealer that gives discounts that's great, but I have always found the best prices at Lindsay Cadillac of Alexandria - Call 1-888-894-1729 and ask for Luke.
thebigjimsho
01-15-13, 11:30 AM
Luke's prices, with shipping added on, is still going to be cheaper...
