View Full Version : No High Beams
olddavid
12-21-12, 10:08 PM
My car- 70k miles- has no high beams. The blue indicator lights up briefly, but no brights. Is there a relay that controls the brights? Or could it be as simple as burned out bulbs? I was operating under the assumption they work in concert, so assumed blown bulbs were a non-factor. Am I ignoring the obvious?
gvjv3
12-22-12, 12:21 AM
There is a relay box, in it is a number or relays. high beam, fog lights etc, it's call K134 relay, the soder connection have gone bad and need to be resoder. look up K134 in the search,
investor74
12-22-12, 11:01 AM
Do the DRL's work? I think a good starting point is to try new bulbs. I was surprised how often my high beams bulbs have blown over the years considering I hardly ever use them until I realized that they are also used for the DRL's. You could even swap one from the low beams to try it.
There are high beam relays in the instrument panel fuse block on the passenger side.
marko69
12-23-12, 04:46 PM
Did you find the problem?
