: Navgation system problem
mkhansa
12-21-12, 12:19 AM
Hello i have a 2008 cadillac escalade with factory navigation and my navigation is always lost on a different road then i would actually be driving or sometimes it be ahead on the street that i would be driving on. I have changed my gps antenna and still the same problem. What the next step i should take
the cadillac man
12-21-12, 01:05 AM
Have you tried setting the zone (I did it one time on mine and now I have forgot how to do it)
mkhansa
12-21-12, 05:58 AM
Hello, im not sure how to do that
MrHolland
12-21-12, 06:26 AM
Welcome to the forum. I moved your post to the proper section, 2007-current Escalade. Good luck with your issue, I'm sure someone will be able to provide you the answer you're looking for.
Cadillac Cust Svc
12-21-12, 10:57 AM
Mkhansa, I recommend checking in with your dealership regarding your Navigation concerns! I would also be happy to check my resources to see if I can find any relevant information to share; please send me an email anytime at Katie_Lucille@gmexpert.com with the last eight of your VIN.
Best,
Katie
Cadillac Customer Service
hollingass
12-22-12, 09:46 AM
Go into config, check your coverage area, see what disc you have. Mine had the wrong disc in it when I got it, still worked but had some issues, new disc fixed it right up
mkhansa
12-22-12, 11:21 AM
Hey i have the first disc that came out on the escalade. If i change the disc would that fix the problem
hollingass
12-23-12, 10:51 AM
I was having some problems similar to yours as well as some others. When I went into Config, Nav, map info, all it showed was the part number, dealer determined this disc wasn't compatible with the Nav unit. They ordered a new one but it is on back order. I tried a buddies disc and it fixed all my problems, now the map info page shows a map of North America and the version and pn. Pm me
Pm me
stogeman
01-07-13, 10:34 PM
I decided to go aftermarket right after I drove off the dealer lot
