: Blower fan works but no heated air. Easy fix or service call?
12-17-12, 02:14 AM
It's cold outside and I can't get any heat to come thru the vents. The blower (fans) work on all the lowest to highest settings but only cold air. Is it an easy fix or a trip to a dealer ( and no car for a day). Please help with suggestions and thank you for your time.
12-17-12, 11:13 AM
Make sure the coolant is full. If that is it you have to find the leak but at least you will have heat.
Only check it when the engine is cold. Even if it is really cold outside you can still get scalded by a hot engine.
12-17-12, 12:32 PM
Set everything to auto & set your temperatures for driver & passenger @ 76 degrees and see what happens. If the fan is blowing cold air the system is coming on right...
12-17-12, 01:29 PM
You should get a free loaner while your car is being fixed. Take it in.
Cadillac Cust Svc
12-17-12, 05:07 PM
Tripletsmom, I do recommend taking your SRX to your Cadillac dealership so their technicians can run the proper diagnostic tests. If you would like me to contact your dealer at any point, don't hesitate to email me for further assistance. I'm reachable via email at Katie_Lucille@gmexpert.com!
Cadillac Customer Service
